Does software make the difference?
Rogier
Rogier Willems
7:12 PM
Maastricht, Netherlands
I have a new Epson V850 and am wondering if scanner software makes a difference in quality. I recently scanned some very low contrast B&W images (whales are like elephants in dense fog...) and despite my best efforts (adjusting the height of the film holder to the best sharpness) and scanning at 6400 dpi I am nog getting good results. So I had the negatives scanned by my local lab with their Noritsu scanner. These scans are much better, nice sharp grain and much easier to work with scans (Tiff files).
I have Vuescan and the original Epson software which I find much easier to use than Vuescan. No processing is done with the scanner software the only thing I sometimes experiment with is the backlight correction.
I have a bias against Silverfast from past experiences. But wil this make a difference in the quality of my scans or is this as good as it gets.
I can kick myself for selling the Betterscanning film holders with my V750 before we moves continents as these things are no longer available.
Any advice here?
When I first got the V850 for our home office I experimented with negative scans. While medium format was OK, I did not care for the results from 35mm. Since I have the Minolta Scan Multi Pro film scanner I use it for film scans. I could probably live with the V850 for medium format, but not 35mm.
Thanks, yes I just scanned some medium format. This looks great but 35mm is problematic.
I am looking at a Plustek or Reflecta. I used to own a Plustek but found it very slow to work with and also needed something to scan medium format.
Now I am in a position that I don't have to sell one thing to afford the other I can combine it by having the V850 do the batch scan and use the Plustek or Reflecta for those images that I want to get a much better scan from...
Unfortunately the really good consumer film scanners are out of production since a long time and are going to very high prices on the used market risking that I might end up with a doorstop when the 15 - 20 year old electronics break....
If the carriers are anything like the V500, I suspect they don't hold 35mm very flat. Certainly mine look to the Mk1 eyeball as though the middle of the strip is higher than the edges.
I scan the negatives as positives as .tiff files, and Invert the colors in the editing software. I use the negadoctor in Darktable for that purpose. This gives me the best results for color and contrast. When scanning 35mm film, most flatbed scanners that I had leave a good deal to be desired when it comes to sharpness compared to professional scanners and darkroom prints. I have no experience with macro setups for digital cameras.
I never had problems with Epson software.
Never needed special film frames, either, because I could handle the rush and keep negatives in the book until they are flat.
Any advice here?
Try scanning with Vuescan, but save as RAW(Tif) and invert using curves in photoshop or similar. Remember to check 16 bit grayscale scanning in output window and 6400 resolution in vuescan. Scan big and downsize your images.
