Aires 35 Rangefinder lenses and photos
oldhaven
1:14 PM
Maine
In the " What Have You Bought" thread RFF member Bernardl asked me to post some photos from the test roll of the Aires 35IIIL that I recently acquired and had to do quite a bit of work to get functional. I thought it would be a good opportunity to start a thread on the Aires 35 Rangefinders to show what the various models and lenses are capable of. I hope others feel free to post their own results from this short lived Japanese maker. I will be adding some photos from a couple of other models I own. Here are a few from the 35IIIL test roll. any flaws probably the fault of the photographer.
Aires 35IIIL, Lens: 45mm f/1.9 Aires Coral H coated 6 elements, Expired Fujicolor Superia Xtra 400
Aires Viscount, four elements 45mm f2.8 Q Coral lens. expired Fujifilm 400
This lens is less common in the first version Viscounts before they had meters added. I have a more common first version 45mm f1.9 H Coral Viscount but had to repair it and have not put a test film through it. A couple of these photos have been posted before, but they are quite good. This camera was CLA'd by Clarence GAss from Kansas several years ago by the former owner.
Very nice. The IIIC is one of the models I don’t have, but I can see it does a nice job. Nearly all of mine have somewhat faded viewfinders, and I use Rick’s trick of applying a small black dot on the window to make focusing easier.
Mine’s pretty good and hopefully the new one will be even better - but if you check the video I posted in a similar thread about these you’ll see it’s quite easy to open and clean the VF/RF
Thank you David. The boat is used on the lower Androscoggin River, where it flows into Merrymeeting Bay. It is relatively shallow fresh water with a 7 foot tidal range, which makes boating interesting. Most of the roll was a bit underexposed as I did not properly account for the yellow filter.
  • Like
Reactions: ped
