Alpsman
Continuation from "Christian.H2003"s thread about the replicas of lenshoods.
Thanx to "drsdwoodgate" who suggested me making some more lenshoods I will continue.
He supported me with measurements of lenshoods I dont own by myself.
The 2.8cm f3.5 hood has a diameter of 70mm and a width of about 20.5mm including the threads [ie. all of it]. It's actually two rings. The bottom ring with the threads is 56.85mm diameter and width of 8mm.
The 13.5cm hood is a diameter of 55.5mm and a length of 41mm.
And now found the 3.5cm f2.5 hood which has a diameter of 66mm and a height of 25mmm.
Furthermore I found the diameters of the threads & piches.
I browsed Mr. Rotolonis book.
According to his book
the thread diameter for the 28/3,5 is 43 mm
the thread diameter for the 35/2,5 is 43 mm
the thread diameter for the 135/4 is 40,5 mm
aaand the thread diameter for the 135/3,5 is 43 mm.
According to "Jonmanjiro" the 43mm thread should have a pitch of 0,5 mm
Browsing through my ongrowing model database I found out, that I've already made th lenshood for the 50mm which have a 43 x 0,5 thread.
at least this on I know will work.
Next step:
I'll deign a test piece with a 40,5 x 0,5 mm thread
for which I need a fearless, patient and brave testprinter who not only will have or have access to a printer but also will own a 13.5 / f4 lens.
All other with a 43 x 0,5 mm thread can be designed.
Greetings: Dieter
Next step:
Greetings: Dieter
