I have a question about my 3.5cm 1.8 lens ~
NIKON KIU said:
I don't have my 2005 camera here at work but do have my vintage 3.5cm f1.8. It is exactly like yours, when turning the whole lens in my finger 360 degrees,it is obvious that is the way it was designed.
Kiu
Thanks you for your checking ~
I can't understand why nikon design it in this unregularly way ~
VinceC said:
If you look inside the mount, what causes it is that large set-screw inside a deep slot. The machining of the edge of the slot affects the tilt.
Now that I stare at it, mine does tilt, very very very slightly. As I said before, this is inconsequential to the lens in use, because the sleeve slides back and forth when put into the focus mount. This spring-loaded movement is actually how the focus helical matches up with the built-in 50mm helical on the mount.
I say stop staring at un-mounted lenses. Put them on a camera and take pictures.
Ok vincec, I got it 🙂
And finally I understood focusing mechanism of my nikon s2 with w-nikkor and 5cm/1.4 !!!
RFF nikon forum is full of experts and real gentleman ~ 😀
Yes, and I have one of these 'defective' tilted new 1.8/35 Nikkors also 😉
Its very interesting how these Nikon/Contax lens mounts work. Much more complicated then the Leica M-mounts I'm used to, but it works and the lens really locks on well and with the focusing it seems more uniform with individual lens.
goliathus
It was Contax who designed the Contax I and then II to compete with Leitz, the famous quote is 'master piece of misplaced...'
Noel
I have the same lens, purchased new with the SP2005. No, I don't see any tilting.
(sorry, pix not well-taken.)
jonmanjiro said:
Ahaaaaa! Hiding the tilt by blurring the background 😉
Haha! That's so funny. I think some of us must be seeing things that other don't see. anyway, one more shot with smaller f-stop for viewing pleasure 🙂
The "tilt" is caused by the set screw holdling on the focus sleeve. Since that is incomprehensible, the red arrow below points to ths slot containing the large set screw. The amount of "tilt" depends on the machining of this slot. (Original picture posted by Kiu).
attachment.php
Ok one of my J12 has a pincushion problem, this is from the top right corner and the building should be vertical.
Noel
The other J12 dont show this problem but it is not unknown that the focus follower needs to have its paint removed and filed to get it to focus with the little focus wheel. Wish I had a Nikon 35mm.
Noel
