350D_user
B+W film devotee
I already have a "litmus paper" test. Ilford FP4+, 125asa, and the "Prestolee Road" location.fidget said:Too bad that the extra tension didn't help. Your plan of avoiding the use of 60th is certainly different. If you do this, with your first film, include a few shots of something of a uniform tone. Sky, a plain wall, in fact anything which will help you to have confidence that the other speeds are working well, so do not show any irregularities in exposure. I would be concerned that problems might exist in one or more other speeds.
Will do.fidget said:Good luck, please share your results with us.
Dave
Ulrich Witte
350D_user said:I've finally recieved the black FED-2 today. Putting the camera through its paces (minus film), I've found an intermittent shutter problem on its 1/60 shutter speed. The second curtain sometimes does not fully close.
All the other speeds work ok, including 1/30 and B. Is this an issue with the shutter tensioning?
Interesting. I have a FED 2 here too, that had the same problem, B and 1/30 are running good, but 1/60 hangs. I've cleaned it and tensioned the second curtain by half of a turn with the screw. Now it works well.
Ulrich
350D_user
B+W film devotee
I only went for quarter of a turn, before I "panicked".Ulrich Witte said:Interesting. I have a FED 2 here too, that had the same problem, B and 1/30 are running good, but 1/60 hangs. I've cleaned it and tensioned the second curtain by half of a turn with the screw. Now it works well.
Ulrich
Half a turn... I'll give that a go tomorrow.
Ulrich Witte
350D_user said:I only went for quarter of a turn, before I "panicked".
Half a turn... I'll give that a go tomorrow.![]()
Don't panic
Ulrich
