Just watched that video. I'm happy using the $35 Lomo DIGITLIZA film holder which holds the film as flat or flatter than this thing. The clue is if you can easily pass the film through it, it isn't exactly holding the film tight.
It is a cool product though.
I just 've checked their Instagram ..and what they did is the entry hole is slightly bit bigger and then it thickens nicely to keep it flat. Should work.
Will see. I'll order one and I'll give it a shot.
I am using Beseler Negatrans for 35mm but I need something for 120 where I can slide the film without cutting it..so this might do the trick.
