helen.HH
To Light & Love ...
The 21mm SA is a film-body only lens (not the M5 or CL); the rear element protrudes too far into the body. And IIRC, it renders the M6/P meterless.I need an excellent wide angle lens for the M9 and M10. Is the SA 21/4 perfect for a digital Leica?
So it is same case as with my Canon 19mm lens and the Rokkor 21/4. Oh well.The 21mm SA is a film-body only lens (not the M5 or CL); the rear element protrudes too far into the body. And IIRC, it renders the M6/P meterless.
If the lens works well on a Leica M262, it should be OK with an M9 or M10. Why not?Hi Raid not suue re: your M digi models
but I have shot 21 SA on digi
here is when I had the M262...wonderful results
Fall, NYC... catching a glimpse
/url] by [url=https://www.flickr.com/photos/helenartemishill/]Helen H., on Flickr
Agreed !If the lens works well on a Leica M262, it should be OK with an M9 or M10. Why not?
I will make sure that the SA 21/4 works well with a full frame digital Leica camera before buying such a lens.Agreed !
TWO more Digital For Raid... M262I will make sure that the SA 21/4 works well with a full frame digital Leica camera before buying such a lens.
You mean in a good way 'killer' Miss f3.4There is the SA 21/4 and the SA 21/3.4. The latter lens is obviously a dedictaed "sensor killer".
Yes, The 21mm f3.4 Super-Angulon .....is one gem of a lens!You mean in a good way 'killer' Miss f3.4
YES SHE IS !!
