rondo
I understand your point. Of course under normal circumstances one would have to step in or step out to achieve the desirable composition, depending on the lens being used.
But if we want to prove the inadequacy of the russian-doll rectangles for describing different focal points, a fixed point of view will be necessary for this test.
if the purpose of the test is to show that one does't need a 35 mm, when you have a 28 available, one will have to shoot wider and crop and scale, and juxtapose the images to see the difference of the two-when shot from the same point.
Of course at the expense of resolution for the 28 mm lens as it will need to be scaled-up. (but that's another subject matter)
Basically what I am trying to say is the following: If I use my 28 mm with framelines of a 35, and I am ready to crop and lose resolution, how much of a difference will there be?
i really wish i had access to both lenses, but i don't...
