squirrel$$$bandit
Does ANYBODY make this size filter/lens cap? Needless to say, this is for a Canon screwmount lens.
the heavystar 40.5mm clipcap fits a treat on canons. And the 40-40.5mm step up also works at the expense of adding some size to the lens.
this? not with a filter....
http://cgi.ebay.com/2NU-CAPS-40-5MM...ryZ79002QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
http://stores.ebay.com/photo-widget
i have an original canon flat 40mm filter thats scratched and in not good shape optically. is there someone that can put in a modern multicoated filter in the old ring?
To elaborate on what's already been said, any competent optometrist can do it for less than $10 usd with your replacement filter -- if the filter holder has a screw-in filter retainer...
You turn the retainer counter-clockwise to remove the damaged glass -- and save it for size... You find, say, a 49mm, 52mm, 55mm or larger filter, remove the glass and take it to your optometrist...He willl use the damaged filter for size and make you a new one the same size and either, he or you, can drop it in the filter holder, screw-in the retainer and you have a brand-new 40mm filter!
I've done it many times...
