50 Hexanon question
tbarker13
shooter of stuff
8:11 AM
Orlando
I'm looking at a lot of different 50mm options for my M8. Included in the mix is the 50 hex. I'm trying to figure out its minimum focusing distance.
Here is a shot with the Hexanon 50/2 at minimum distance of 0.7m:
Terrific lens and for what they go for ... incredible value! I suspect they may go up in value as time goes by and the build quality should keep them keeping on!
If it works on Leica film bodies, Zeiss Ikon, Bessas, etc - It's M8 to blame - not Hexanon lens!. However, I have seen many posts that Hexanon works just fine with M8 and RD1. So it may be THAT Particular M8 and/or Lens.
'if it works on Leica film bodies'
What if it doesn't 'work' on Leica film bodies but the resolution of film is not adequate to reveal the flaw?
I think film resolution is just fine to check if lens focuses correctly. Plus as I said, there are posts out there that Hex works just fine on digital cameras - M8 and Rd1. But, if you are uncomfortable with getting Hex - there is always Summicron. 😉
