Calzone
Gear Whore #1
- Local time
- 10:53 PM
- Joined
- Nov 11, 2008
- Messages
- 16,953
- Location
- The Gateway To The Hudson Highlands
Here I have loaded a full length "dummy roll" onto my new Jobo 70mm reel. Actually I think it would be useful to have more than one of these reels. This will fit the Jobo Multitanks; even the single Multitank 2 one I believe. Will have to check that. I know it will fit my Multitank 5 and Multitank 6. USEFUL!!
Jobo reel 70mm Dummy full load by Nokton48, on Flickr
Dan,
If that is the JOBO 3075 reel that can handle 15 feet of 70mm film then the correct JOBO tank is part number 3035 which holds 1.5 liter.
There is a JOBO 5025 loader that completes the kit, but I wonder how easy or difficult it is to load a big reel like that, and also how it compares to the stainless steel reel since you own both.
I'm moving forward also. It seems that the Rollie 400S when bought in a 70mm 100 foot roll makes a 120 equiv for only $2.50, so this is the most cost effective way to shoot 70mm, especially if processing is performed by me.
The good are many: 400 ISO can be pulled to 100; likes Rodinal for convenience and easy one-shot using a liquid developer; clear base for scanning; fine grain; high contrast; can be used as an IR film or standard film for flexibility; and is a fresh film that is available in 120 for testing and evaluation.
It is reported that the contrast is good for overcast or diffused lighting, but for high contrast lighting pulling film and using compensating effects are required for bright and high contrast lighting.
The bad: can be overly contrasty and ISO needs to be pulled for high contrast/bright lighting; does not respond to Diafine well; has to be ordered in Germany and shipped; and extra precautions required in loading (really-really requires subdued lighting or fogging will occur).
The ugly: to effectively use this film as an all-rounder some skill is required to somehow moderate contrast by either pulling the film speed, or creating a compensating effect. I'm not convinced that Diafine can't be made to work for moderating the contrast. Generally Rodinal accentuates grain in higher speed films, but not with Rollie 400S. One reviewer compared the grain to Delta 100. Hmmm.
The cost of a 5 pack of Rollie 400S-120 is $39.95 at B&H for a cost of almost $8.00 a roll, but 70mm ordered from Germany lowers the cost to $2.50 per 120 equiv. I think for testing I'll but a 5-pack of 120, but on a per roll basis it would be great to shoot 70mm because it would be cheaper than shooting than even 135 when you could buy Arista Premium (rebranded Tri-X) for $2.89 a roll.
Another thing that makes shooting 70mm cost effective is you kinda get a free gym membership.
Cal
