Nokton48
Step 5 Use a dummy 220 70mm roll to set reel spacing perfectly by Nokton48, on FlickrAssemble the reel, and use a 220 length of 70mm film to set the spacing between the two spirals. Do not be in a hurry, this one goes on smoothly without any issues whatsoever. Roll the complete dummy film all the way on to the reel, make sure you are well satisified how it is going
Step 6 Practice winding full roll onto reel until you are satisfied by Nokton48, on FlickrWhen you are well satisfied that the roll goes completely smoothly onto the reel, remove the film carefully, and then drill and install the three stainless steel screws to lock everything down on the second spiral. After final assembly, make sure to try loading the roll a few more times to make sure all is good.
The reel is now ready for use in the small Paterson tank.
