A Forgotten Accessory? ~ DR Leica VIOOH Finder
Tom, I'll post some pictures of mine when I get home today (and remember to do it).
I did not get round to cleaning it last evening. The front and rear lens are in good condition, it's purely the prisms that are hazy.
Because of the haze in the VIOOH, I prefer using my black-nose VIDOM finder. It's no problem as I don't have any lenses with focal lenghts other than 35mm, 50mm, 90mm and 135mm.
Rick,
I spent another two hours laboring over my VIOOH last night...
Word to the wise - don't touch any of the screws on the big knurled selector ring, especially the small flat-head screw up near the indicator scale ! :bang:
Removing the four screws on the back to expose the prism assembly isn't bad; the cover is probably a tight fit in the body.
The prism bracket is secured by two screws to the upper right of the bracket, as you look inside from the back.
The small screw I've been battling with has to do with the detent (click-stop) spring/mechanism; I shouldn't have removed it, and I have not been able to get it to re-thread into whatever has the female threads inside.... 😡😕🙁.
Good luck cleaning your prisms !
Frank 😎
PS: RE - VIDOM - any usage issuses / challenges regarding the inverted image ?
You get used to it. Taking portraits without turning the rear of the viewfinder 90 degrees is a good way to get sea-sick though. 😉
I'll try cleaning the prisms on the VIOOH this evening. I'll flush it with some alcohol and lighter fluid for now. Wiping dirt from between the prisms is going to be hard though.
off topic: Two drops of lighter fluid was all it took to get my new Rolleicord going, one in the shutter and one on the winding know to get the frame lock working again
Also managed to get my aperture rings on my Summar and Summitar moving freely again with a very small drop of gun oil. Sweet!
All that needs to be remedied now is the separation in the Summitar.
As promised. Pardon the quality, my 2mp p&s ixus v2 was the only thing with a charged battery 😉
Right, Tom has a straight-sided one. It's the latest model with 3.5, 5, 8.5, 9 and 13.5 cm focal lengths, probably from the late fifties-early sixties. I understand the curved-sided lyre shapes, like Rick has, were earlier and not numbered. They have a 7.3 cm focal length instead of 8.5 cm. I have two VIOOHs, one lyre-shaped without number and a later, numbered (89980), straight-sided one, like Tom's. However, both have single distance scales, feet and meters, respectively.
BTW, I cleaned the prism surfaces of both of them as described above, and that made a lot of difference.
So that seems to be a 1947 to 1948 issue, so built right before mine, the stamped "Germany" came about around late 1946/early 1947.
VIOOH`s are a collectors hodge podge of variations, there has to be at least 10 to 15 different types, with and without speical engravings etc.
Nice shots BTW, I like the jacket, I`m going to be making up a Postwar/Korean War era style jacket sometime myself.......to go with all my 1945/46 gear.
Tom
Whilst cleaning the prisms I saw there was a 4-digit number on the underside of the foot.
Perhaps mine was put together from different finders?
I need to let it dry to determine the amount of improvement. There's some lens-cleaning fluid between the 3rd and 4th prism 🙁
Funny you should say that, on the 20th it's Veterans day in the Netherlands. I'm putting together a Korean-war 2nd Infantry Division uniform. Dutch troops fought with the "Second-to-None" division wearing US uniforms.
I pretty much have it all except the black jumpboots and the Indian Head Patch.
I have a WW2 war photographer uniform, but I want to change it over to Photo Signal Company for the big 2nd Armored Tour through Belgium and The Netherlands in September.
As we both know that postwar 1945 to 48 period at Leitz was pretty crazy, quality control was pretty relaxed, and they put equipment together with anything they could get there hands on, with 96% of all production going to the American Forces Post Exchange Services and also US Air Force and US Army contacts, it could very well have been a finder put together for such an order, I`ve never noticed numbers at the bottom of the foot before, but that version you have is the pre 1948 styled one, so I`m sure it was just made up for some kit that an American received........
I like the "Black Nose" VIOOH`s the best from all the postwar variations, it was issued 1945 and 46 only, made untill the heavy duty chromium batches could be mixed up, by June 1946 the Chrome problems were settled and paint quality also improved with the return of Semi-Gloss Black Lacquer`s for the accessory parts etc.
Tom
I've mentioned it before a few times that mine came from KEH. In the light of your information it could possibly be a post-war US occupation forces bring-back.
It was marked as "UGLY" at KEH, so I knew what I was getting.
Time to check if those seems between the prisms have dried out properly.
I ran into some trouble cleaning the VIOOH prisms. It looked like there was moisture and air bubbles trapped between the 3rd and 4th prism. And as these are glued together I can't get at it.
So with nothing to lose I thought about possible solutions. First thing that sprang to mind was give it time to dry. So I stuck it in the sun for most of Saturday. All this did in my mind was expand the bubbles, making the the view through the prisms even worse.
Then I thought about pulling the prisms apart, but material used to bond them together looked pretty tough.
So I thought about it some more and figured I might as well force dry it.
So I stuck it in the oven at 50 degrees Celcius at first....until the freezer engaged and blew the fuse.
So the old oven was a no-go with my new freezer. Well, there was the microwave/oven combo on another circuit.
The problem was, it didn't go lower then a 110 Degrees Celcius.
In the end I chanced it and left the prisms in there for 10 minutes.
Big improvement. There's still some moisture but only at the edges.
After reassembling the finder the view is still slightly hazy but much better than before.
I have known of the "DR Summicron" since around 1968, when I used one briefly. Before coming to this forum, I had always heard it called the "near range" Summicron. This may well be a difference between US usage and British.
It is a pleasure suddenly to learn that my Canon SLR lenses, bought in 1975 and sold not so long ago, were all "dual range" as that is defined on this thread. But then no Leicaphile would so much as look at them...
Leica refers to what I had always heard referred to as the "DR", as the "Summicron 50mm f2 with close focusing" in the M8 manual as one on the list of incompatible lenses.
Mine came with an M2 body as I recall, and I was looking forward to using it with the M8 until reality struck. ;-)
There was some confusion as to whether it could be made to work, and as I was told Leica only made one close focus lens, the Summicron Dual Range, and Close Focusing had to be names that evidently commonly refer to the same lens.
I took less guilt that more informed people than I were confused for a while. I suppose there is little demand for any sort of modification to the M8 or some of the other recent vintage M Leicas for which I have been led to believe also have some compatibility issues.
Regards, John
Payasam,
I have a Vietnam era F-1 Mech and I love it 🙂 The Canon f1.4/50 and the f1.2/55 in are great shooters!!!!
I do like to have the feet labeled out for me, as I`ve alway been a dummie with match, don`t have a clue how to change over to meters.......
Yes, while it`s going to cost more......I`m going to have Don Goldberg, go over my VIOOH`s, while he also has the internal and external replacement parts as well, I have a WW2 era, a 45'/46' Black Nose and this Dual Range one, I don`t really use them, they are neat collectibles.....well, maybe I`ll break them out with the 90 Elmar and 135 Hektor, sometime? 😉
Tom
India went metric in 1957, so we had to re-learn how to think measurements: although Imperial units survive even today. I confess that it took me over 30 years to begin to think in kilometres rather than in miles; and in estimating shorter distances I still think in feet rather than in metres. It helps that a metre is not so different from a yard. As a schoolboy I ran the 100 metre hurdles, known at the time as "110 yards".
I have a lyre-shaped dual scale VIOOH, 3.5,5,7.3,9,13.5 focal lengths, E.Leitz Wetzlar Germany (as the one above). Flat black paint, satin chrome; on the bottom, towards the front of the shoe mount is what may be a serial number: 4323 (engraved, in black). Unlike the finder in the first post, the "m" in "Mtr" and "f" in "Ft" are lower case, not upper case letters.
