kevin m
Has anyone purchased an aftermarket diopter from the ebay seller "etefore" (or anyone else) their M body, and if so, were you pleased? Thanks!
literiter said:What does a "magnifier" do for the M series cameras? Will it work in conjunction with correction lens etc.
marke said:Well, on my M6 TTL with the .58x viewfinder, it turns it into a .72x viewfinder. This helps when trying to focus my 50mm. But then the 35mm brightlines are no longer visible when using it, so I only use it when I know I'll be shooting my 50mm for a awhile.
I don't know about the 3rd party items, but the Leica correction lens will screw onto the Leica 1.25x magnifier. Yes, you can use both together.
