Agfa Rondinax 35u
The orange Lab Box is on my list! Tom, thanks for the information about caffenol and Rondinax tanks. I bought a changing tent from another member and picked up a single reel developing tank for that project. Over the last few weeks, I have gathered all the essentials, beakers, storage bottles, developer (HC-110), fixer (Ilford Rapid), clips and even a film retriever. The weather has been hit and miss the plenty of northwest rainy days so I'm only about halfway through a roll of TMax 400. I did drag out the Plustek and have been practicing scanning on a box of thirty year old Kodachromes. Thanks for the information and the encouragement.
Concerning caffenol , have been using it for a few months now. An accurate scale is pretty much necessary ( at least to 1/10 gm) . PM me if you have any concerns I can help you with . HC-110 has been my go to otherwise for a number of years now . It much more satisfying and faster doing B&W at home .
Peter
Seems rather complicated. I use SS tanks & reels, a dark bag for loading the film. Tanks, reels, funnel, chemicals, dark bag, hanger with clothes pins - the whole shebang fits in a 7 gallon garbage can that resides under the bathroom sink.
Seems rather complicated. .
The point I want to make - the more B&W film users and home developing options to choose from the merrier I will be.
I used a Rondinax 60 for 120 film for a couple of years - 46 years ago - They do work and it wasn't very complicated.
The one thing I've learned courtesy of the internet is that there are many ways to shoot and develop a roll of film.
If the availability of a film developing tank that does away without hiding in a dark closet or using a changing bag/tent will bring in more people into the D.I.Y film development world, then I'm all for it.
Now a days, I'm stuck in my routine with HC-110 @ dilution H or Rodinal @ 1:50. I use Patterson tanks, of which I have three sizes. Also, I stubbornly shoot negative film at slightly less than box speed.
The Rondinax is a gadget and if it makes developing film at home easier, then it’s worth the price. It was a lot cheaper and probably more useful than a lot of other gadgets I’ve accumulated over the years. I did add the few additional items for traditional tank developing so I can try both.
I actually found a Jobo tank recently. (On it’s way to me now)
Has one issue, a broken retaining clip. Going to try and either fix it or make a new one.
Apparently the Jobo model 4324 is the same as the 2400. Mine was cheap.
Thread resurrection time!
I’m a big Rondinax fan. It suits me well and I really like using it. I’ve never had a problem and would even go as far as to say it’s actually quite relaxing.
Now - I’ve just seen the Agfa RONDIX tank, which until now had completely passed me by. It looks great, just a simplified system and even more compact. Easier to dry, too. So - what’s it like? I suppose the only worry is that the film comes into contact with itself a bit, but then it does in the camera and cassette anyway, so probably not an issue?
I’ve just put a bid on one as I’d like to have it anyway, and of course I’ll try it - but I’m interested to hear if anyone here has experiences vs the Rondinax
Cheers
I've used the Lab-Box for several years; it never occurred to me to look into the Rodinax and see how closely the two are in terms of design and function. Reading through the Rodinax instructions online, I noticed some details that translate to the Lab-Box, such as unwinding about 2" of film onto the reel and noting that the outside, trimmed edges of the film angle downwards to feed correctly onto the reel. Also interesting that they describe the method of turning to agitate as a jerky rotation about half-turn every 2 seconds. I've never been quite sure of what the most effective way to agitate the Lab-Box is, and most of the material made for it shows a constant, smooth turn of the wheel, rather than a quick, jerky half-turn. I might try that and see what the results are like.
I've never seen the RODINX tank. There doesn't seem to be much material on the web.
  • Like
Reactions: ped
I've had the Lab Box for some years now, and still have the Agfa Rondix 35, Rondinax 35U and Rondinax 60. All of them work well. That said, I enjoy the feel of the Agfa tanks much more than the Lab Box; they're just a little nicer in use. I have the fancy top for the Lab Box with the thermometer and such, but thus far I haven't found any need for it ... all B&W work for me, the temperature lid is best for controlling with the precision needed for color development.
It's good to have options. 🙂
G
I like the look of the lab-box but part of me thinks if it ain't broke... I saw recently that they were releasing a motorised agitation accessory which looks interesting. This allows for start-stop agitation. On my Rondinax I use the arrow on the wheel as a guide and turn it roughly 180 every couple of seconds throughout the 6 min run, using Rodinal 1:25
I have the Rondix, Rondinax, Jobo and Kodak daylight loading tanks, Rondix is my favourite. Never any issues, beautiful results with Tri-X and Ilfotec HC.
I just watched their video for the motor accessory, the "M-BOX" which we could debate the accuracy of, since it's not a box, just a motor which mounts to the crank on the Lab-Box, but...
It looks legitimately very convenient, and I like that it has three different settings. I'm curious about the lower of the two development settings, which employs short pauses in the continuous agitation. I may have to give than a try manually.
The problem, aside from availability, is the price. $139, just for a motorized crank? Not sure I can justify that for my frequency of developing. Edit: it's $199 on Cinestill's website in the US!
Here are the instruction manuals for the Rondinax-35u, Rondix-35, and Rondinax-60. Enjoy!
G
Dear Board,
Lomography has a daylight 35mm tank too. You can buy the tank with a leader retriever for less that you can find a 40 year Rodinax or JOBO daylight tank kit. I got mine on special with a combo kit including the Digitizer cell phone scanning kit. The scanning kit is OK for quick checks to see if negatives are worth doing full scans or DSLR scans, but I prefer to use a camera and a JJC macro-lens adapter kit. I got everything at a package price with a coupon in the Spring of 2025 otherwise I would have been fine with the just the tank.
So far, I've only done 2 rolls with it, but I got pleasing results for me using Kentmere 100 and 400 and Cinestill Df96 one bath developer. I also have a Lab-Box that I bought from a member here several years ago that I've used for various 35mm and 120 films. PET based 120 films cannot be loaded properly in the Lab-Box, and PET based 35mm films can be difficult to cut off the spool but I'm happy with the results I've gotten with it.
I have most of the next 2 weeks off, I think I'll try doing some color film over the Holidays.
Regards,
Tim Murphy
Harrisburg PA 🙂
The Rodinx instructions boggle my mind, I can't understand how the film is spooled on inside the tank. It's definitely an interesting design.
The Rondinax tanks have a standard spiral film spool that is loaded by the feeder guide.
The Rondix-35 tank has no spool: just a center hub. The film is constantly in motion when being processed, sliding past itself and over itself constantly as processing progresses. It's such a simple and elegant design... 🙂
G
It's here - I had to laugh when I first saw it, as it's just TINY!! The mechanism of the spool to hold the film looks really clever and I'm looking forward to trying it. Interestingly, it still uses 200ml of liquids but I suppose it totally covers the film as opposed to the Rondinax which immerses half the spool.
Yes, the Rondix-35 is compact and light enough that I've actually dragged it along on travel a few times, with small ampules of developer and fixer concentrae to mix up with water, so that I could process some film on the go in my hotel room and examine my negatives with a loupe. (when packing it for a trip like that, I store the handle and its securing bolt inside so they don't get damaged ... there's just barely enough room to do that. 🙂
200ml of fluid fills the tank portion of the Rondix just covering the top of the spool. Of course the film itself displaces a little more volume so the liquid level when static with the film wound all the way on is a bit higher. Since processing involves continuously winding the film back and forth, wrapping it around the spool in the reverse direction each time, the chemistry is very evenly distributed along all the film surface inside and out, as the film wipes itself and stirs the chemistry as you reverse the winding direction.
It's truly a marvel. I have two of them, which I originally bought so that I would not have to wait for the tank to dry when processing more than one film in a session. And then I realized that, since there is no reel to be sticky if damp, it doesn't matter if the tank isn't 100% dry at all. Whatever residual few drops of water are left after rinsing it are completely inconsequential. So, in the end, my second Rondix is still brand new in the box as a spare should I ever drop and crack the first one. 😉
G
I really love the little Rondix and it is my go to development system (and I have heaps of alternatives). The only time I switch is when I have shot more than one roll in a day, then I fire up my ATL-1500…
  • Like
Reactions: ped
