any solution for dark rangefinder in XA
zsero
5:41 AM
I have just bought an XA, which I really like. Its such an inspiring camera because I can bring it with me all day. I like it every time I find it in my pocket, such a compact tool for artists!
My only problem is that the small rectangle for rangefinder focusing is not bright at all. I mean that for some very contrasty scene, like looking at a corner of a TV screen, its OK, and when I cover the viewfinder hole, its a shining bright rectangle over the black window, but for everyday use its almost impossible to focus. I tried an XA of my friend and it had a much brighter/contrasty rangefinder.
Do you know what are the possibilities for servicing this issue?
1. Bring it to a professional who can do it
2. Try to clean it myself
3. Just buy an other XA?
Can you point me to any website about how to clean a rangefinder? I have heard that there is a small semi-mirror-like thing which needs to be re-silvered but I dont know how these works.
My solution was to ignore the rangefinder and use scale focus. For a 35mm lens, focus is not critical at smaller apertures and moderate distances.
Richard
Solution for dim XA viewfinder
I have a solution/work around for the dim XA viewfinder. I found this on the web and I am currently using this fix on my XA. First I used tape, and then, when it worked so well, I made it more exacting and permanent with a sharpie. Astronomically improved my dim XA's focusing abilities.
http://rick_oleson.tripod.com/index-165.html
Basically, you black out the center of the main viewfinder window, creating a very contrasty split image focusing area. Worked like a charm.
This fix has a huge advantage for me with a camera like the XA: cost. It's practically free. No $100 repair for a $40 camera if you use this one.
You've no doubt done what you could to clean the rf window on the front?
It makes a big difference..
A really permanent fix is to get an xa2 instead..
Yes, I know this solution, it's not a pernament fix, but better than nothing. Do you think it's really hard to disassamble and assemble the camera and it's rangefinder by myself?
