barnack accessories
I like my Visoflex setup with bellows and 135mm Hektor.
damn dude ---- serious gear
That is one serious attachment, Vince.
PF
It was a bit fiddly to adjust for proper focus (so that when it's in focus in the viewfinder, it's actually in focus through the lens), but it actually worked quite well. It had a flip-up magnifier as well as a ground glass, and this particular model was for the Standard C (they did also make a version for the Leica II). I no longer have it, but if you can find one, they're fairly pricey.
How about one of these? It's a VACU-? but I don't know the last letter of the code as they vary.
As you can see it hasn't got the shutter guard fitted but that's not a problem, just laziness on the part of the photographer.
Regards, David
For something of truly little use there is always ELIDA
Now, come on, be honest. Who amongst us hasn't been seduced by the finish and quality of an ELIDA but has absolutely no use for the damn thing!
Yes, sorry, I men ELDIA the contact printer. Mine was free too in a box of various bits. Can't even find a use for the knobs.
The elusive ELIDA is so rare I have never seen one for sale and it is not listed anywhere!?!
Is it part of a flashgun assembly? The only name I can track down is VACUB.
Thanks. I've only discovered that there seems to be a different letter for each version and body. So the end number could be anything. The shutter speed dial has to be changed for one with a cam to fire the flash. You can just see the micro switch in the photo.
I'm not bothered by flash but it came with a lot of other flash bits of the same vintage and so I put it on display and (usually) forget about it.
Regards, David
Yes, it is the sync mechanism that trips the flash-gun (blitzlicht).
There's another element: a replacement shutter-speeds dial with a little finger on the edge to trip the reed-switch in the VACU.
I think there were two basic versions, one for bulb sync, the other for strobe (electronic flash).
The little wave-symbol inside the oval indicates which version this is , but I don't remember which symbol is for which.
The earliest Leitz flash guns are the most elaborate and nifty, in my opinion: they consisted of a replacement baseplate with the flash contacts incorporated(SELSYS?), then a bracket the wrapped around the end of the camera, to which the battery tube clamped, then the dish-reflector sliped into a stirrup strap behind bulb socket (Edison screw-base, with an adapter stub to bayonet base which positioned the smaller bulb at the optical center of the reflector dish). I got one in a "goody box" of Leica sundries from KEH a long time ago. Mine seems to be from the 1930's the battery tube is black lacquer, and the bright bits are nickel.
I have actually used it. 😀
I would love to get the various VACU sync gizmos for my later LTMs.
I also have a GeissKontackt add-on flash sync.
Back to the VACU-X
Back to the VACU-X
I've the rest of the flash outfit that goes with the VACU- A to whatever. Plus a collection of enormous flash bulbs and so on. It includes a nice crackle finish mounting bracket and so on. I think the bracket is a later one as it's got shiny chrome.
Luckily, I dislike flash and seldom use it; well, flash bulbs were smelly and cost over 9d each out of my pocket money. Even when I got a primitive electronic flash in the late 50's I didn't use it much because of the 90v HT batteries' cost and the fiddling about putting the bulb in place. It was about five inches long from memory and stored in a metal tube filled with cotton wool.
Regards, David
