woodgeek
I've got a problem with a Canon F-1N that I was recently gifted. When there is no battery installed, the shutter will fire. With a fresh battery installed, the shutter won't fire on Normal or Self-timer mode. I thought it might be a problem with the battery voltage but I checked it with a voltmeter and it measures just under 6V. Using F-1N's battery test, I get a reading between 11 and 18.
The metering seems to function just fine--checked with Normal, Hold and Light. I compared the meter readings with my older F-1.
Any guesses as what might be causing my electronic shutter not to fire? The camera looks almost brand new on the outside. Inside the light seals are brand new.
