Canon LTM Canon flashes
The different battery packs would be useful if you were using additional flash heads with bulbs off the one battery unit.
The capacitor is readily replaced with a new electrolytic capacitor from Radio Shack or Mouser Electronics, just a matter of being a little creative in how you connect it to replace the original.
Bulb flashes
Bulb flashes
Any users of the old bulb flash units? I know the old bulbs are hard to find and the more modern unints are easier to use but I wondered if the old stuff perhaps gave a different rendering to a photo. I use a Canon P , and sometimes a III or IIs2
What I am asking is :Like the older lenses, does using the old flash units help to render a more antique look to the pictures? Has anyone noted a difference?
Not in the character of the light, per-se. Well, it may be slightly less of a point source, given the size of the reflector.
More important is that (presuming you use a 6B or 26B bulb), you can shoot at shutter speeds all the way to 1/1000. Also, you also have the option of smaller apertures, since they pack more light than most electronic flashes.
