Canon vt
Letien
12:31 PM
Hi
I try to put back the top part of my canon VT after cleaning the RF. Anyone has a repair manual can help me?
Thanks in advance.
I've got a manual for VI-T but not V-T. The controls are a bit different, so it might or might not help.
What specific problems are you having?
Actually, my friend take it apart to clean it for me but now he is too busy to put it back. I would like to do it myself if I have a scheme or picture of part assemby. I hope that there isn't much different between V and VI.
Thanks
Brian Sweeney said:
It should not have taken your friend long to put it back together if he knew what he was doing. I do not think I'd use him for repair work again! Getting the top plate back on can be tricky. I found that the top plate for the Canon 7 has to line up just right, or the shutter release will not work.
My friend is actually a mechanical genious and also a cameras expert ( certified leica tech). It's just a familly illness event that make him too busy so I don't want to bother him.
Brian,
Thanks for the tips on retina IIa. Unfortunately, mine have a broken tip rachet. I will continue to post picture after I fix it.
Thanks
