classic lens on modern camera?
vfrazz
vincent
3:45 AM
Damariscotta Maine USA
I've done some searching, but not finding. I'm interested in mounting a 1938 Contax lens (probably a 50mm) on any camera body with a meter. I do believe the Bessa R2C will do it, but I can't believe the price! Any others, please?
The R2C is the only camera it will mount to directly with a built in meter.
Otherwise you are looking at adapters to convert the Contax mount to another camera mount. That could be Leica mount (film or digital).
If digital is OK you could adapt it to most mirrorless cameras with the appropriate adapter. I use my Contax on a Fuji mirrorless camera. The adapter was around $60. The field of view could vary depending upon the sensor size of the camera you are adapting to.
Shawn
A contax to Leica adapter is available but is not cheap.
https://www.ebay.com/itm/Contax-Ran...775855?hash=item51d0ffcc2f:g:tNgAAOxyzpdTjqBZ
Though you may not wish to use your on a Leica, Leica M mount is a bit more ubiquitous than Contax and may provide more options. If you are willing to go digital of course mirrorless cameras then become a very real and competitive option because Leica to mirrorless adapters are cheap and can be stacked with your Contax to Leica adapter.
If not and price is a real consideration why not use it on a Kiev (Russian copy of a Contax) with an accessory voigtlander VC meter mounted on the accessory shoe. The meter is not especially cheap either though but it does provide a few more options and effectively provides you with a metered camera (or sorts) mounting a contax lens.
https://www.ebay.com/itm/Excellent-...856467?hash=item363b57fe53:g:g8cAAOSw-UNbdJ3r
The original way is to use a Contax III or IIIa.
Cheaper alternatives include the Kiev III/IIIa, 4, 4M, 4AM.
All have selenium meters.
Henry Scherer puts new selenium meters into the Contax when he overhauls them. I don't know how much stock he has left though.
The later Kievs still have working meters.
So you want to use the 1938 Contax mount on a film camera or a digital camera?
I have a 1938 Zeiss lens in ltm mount (converted from Contax). It is a great lens overall.
...thanks for the responses...appears to be a no-go for me...I've photographed with G's and Arias, and was hoping a "modern" body might accept the old classic lens, rather than the older Contax/Russian bodies, but...
message Raid: hoped to fit to a film camera...
If you had aimed at a modern digital camera, I would have suggested a cheap M 4/3 such as Olympus E-PL1 with a $15 adapter.
Leitax.com ???
It won’t work on an SLR, as it wouldn’t focus to infinity. only adapting option is an interchangeable lens RF, that reduces the choice to a body with a Leica M bayonet...there are quality adapters for this but they aren’t cheap. R2C may be the best option
Raid, I believe you once had both the 1.5 and 2.0 versions of the postwar Zeiss Jena Sonnars (you mentiones having bought the 1.5 after owning the f2. Did you get to compare the two? If yes, could you comment here on them (out of focus rendering, microcontrast, etc)?
