Vics
I believe that's true, especially because I nearly always shoot wides at small apertures. It was a VERY pleasant surprise that I could opt for the Nikkor if I wanted to. I like it very much on cloudy days...
That's too bad. Maybe the head bartender has been fooling us all along with this photo below (found here)...
Amedeo was not making adapters when that pic was taken. I used an original Orion adapter.
Stephen
That's interesting to read, Stephen. I've also tried with an original Orion adapter. This one in the classifieds right now, actually. When Akira (aka Zen-shooter) visited Tokyo a few years back, we went to Sanpo Camera where we tried attaching both an external mount and internal mount Nikkor-N 5cm f1.1 to his adapter. We were unsuccessful in both cases. Slight variations between Orion adapters maybe?
I was able to mount my S-mount W-Nikkor 3.5cm F1.8 lens on Akira's Orion adapter (not possible with my Amedeo adapter) although the adapter/lens combo cannot be attached to a camera.
Amedeo is basically CYA (covering his ass). It's easier and safer for him to make a blanket statement that only 50mm lenses and longer will work on his adapters than to try and test all the options and make a comprehensive list for 35mm lenses and wider. That way he avoids being held responsible for someone damaging their wide angle lens on one of his adapters due to his list stating it would work but in practice it didn't. Smart thinking on his part, really.So, from the above list, some show that they will mount AND focus, and others that will not mount. Is the list, the Amedeo site, or something else in/out of synch? Thanks!!!
Thank you so much! Only two of the listed 35's even fit -and they both focus. What about the uncoupled adapter designed especially for wider lenses? Nothing fits? Or are non-metered M's not considered?
I love, love, love my coupled Amedeo and Contax 50/1.5 Sonnar! I would like to add a 35 Biogon to the mix, but I find myself a bit confused. For reference, the following is from POST #2 for convenience...
35/4.5 Carl Zeiss Jena Orthometar (YES - will mount and focus properly)
35/2.8 Carl Zeiss Jena Biometar (YES - will mount and focus properly)
pre-WWII Carl Zeiss Jena 35/2.8 Biogon (NO - rear element too large, interferes with rangefinder mechanism)
post-WWII Jena ("E. German") coated version (NO - rear element too large, interferes with rangefinder mechanism)
35/2.8 Zeiss-Opton (NO - rear element too large, interferes with rangefinder mechanism)
35/2.8 Carl Zeiss ("W. German") Biogon (NO - rear element too large, interferes with rangefinder mechanism)
35/3.5 Zeiss-Opton (NO - rear element too large, interferes with rangefinder mechanism)
35/3.5 Carl Zeiss Planar (NO - rear element too large, interferes with rangefinder mechanism)
Now, the Amedeo site shows the regular adapter as coupled for 50 and above and that wider lenses will not focus. Also available is one that is uncoupled for 35, etc. that will allow fitting large rear element lenses to non-metered M bodies. So, from the above list, some show that they will mount AND focus, and others that will not mount. Is the list, the Amedeo site, or something else in/out of synch? Thanks!!!
the way to shoot the larger rear element lenses on another camera,
including the Biogons, 35/1.8 Nikkor, 50/1.1 Nikkor,
Is to use the Rayqual SC to NEX adapter
on a Sony A7 or A7s.
Stephen
Did anyone try to attach a 21 mm Biogon via Amedeo's wide-angle adapter to a Minolta CLE?
According to his web site it it will only work with unmetered cameras. But I recently found an article in a Chinese blog where the author successfully matched lens and camera. Unfortunately I do not understand Chinese and the Google translation is quite poor. But maybe anybody of you has tried this combination (or can help me with the translation of her statements concerning the CLE)?
Of course I contacted Amedeo and Chnchen (the author of the blog post) before raising this question here. Amedeo thinks it would not work because of the light meter. But maybe it cow work due to the fact that it is positioned a the bottom of the camera. No answer from Chchen so far.
Greg
Hello everyone,
Does it make sense to buy nikon S to LTM instead of S to M? So we can use LTM-M adapter to change frameline in M if necessary? Is there any drawback from doing such (e.g. more prone to focus error)? I understand that S-M adapter will enable 50 frameline.
Thanks!
