Contax I ribbons
Sounds like something is sticky. Could be due to cold temperatures as Highway 61 says.
If you've got a darkroom or a change bag you could just open the camera and cut the film. Put the exposed part in a canister or a film tank.
Anyway, I hope it's nothing too serious.
Good point. Actually it was cold here. I never thought about this
I will shut inside a few time and unload the film.
Instead, I would remove the film in the darkroom right away as per Rick's advice, then wait for the camera to warm up, then look for debris inside the camera, then (very gently and very carefully not to overheat anything in the camera !) heat the camera on a radiator or with an hair dryer, then just try to make it work with no film in it.
Thanks, I unloaded film. No debris inside, It work a little and start do it again after 20 shuts. I can see issue with shutter cover plate. I guess, because my shutter cover plate has missing original spring and I have installed some different spring there. It cause a problem now. I need to fine a better replacement.
.. I totally wrong!. It nothing to do to the plate. It is my home-made shutter winding knob. Looks like I make it from too soft metal. Over time shutter speed selector has "shift" a little. This leads to desynchronization top curtain. Basically top roller/curtain not winding enough and everything shift, my 1/200 become 1/100, 1/500 become 1/200 ... and so on. I really love my hobby...!! 🙂[FONT=MS Trebuchet, Arial, Helvetica][/FONT]
You need to find a good original winding knob made of brass from a donor camera, wrecked otherwise.
Any way to make a stronger part? Or at least stop it from shifting?
I should have used some 25/75 beam-splitter material to replace the half-mirror on my Contax I instead of the 50/50 beam-splitter. That would have given me much better contrast with poor mirror on the right side. Like using an orako/okaro filter on the Leica.
I sure it could be done. I looking for minimum "machine shop".
I have many old microscopes, what has some brass knobs. I will try to modify them for this.
Just for someone Who interesting how it work, and what is a critical parts
it may be difficult to understate for who never been there 🙂
Wow Deklari! I am just working on these parts! Thanks a lot!
Erik.
I have a few issue: one is over winding, there is a winding stop mechanism (I have show as "Lubricate" on picture). The lever on film winding axle was miss the "stopping pin". The "stopping pin" moving back and forth by spring during winding. In my case it was stuck (at forth) and didn't stop the lever. It require a good lubrication.
Second issue with release mechanism. There is brass "pushing ring" under central gear. This ring was concave to separate the gear and winding wheel when you press the release button. In my case this ring not concaved enough (or changing angle over time).
Deklari, Excellent description, many thanks! I have a film in the Contax at the moment but because I am a little afraid of upsetting things I do not understand I am using the same shutter speed for everything!
Yes, it is a most interesting mechanism. It can work in different ways. With the camera I am working on now I can get an amazing variety of shutter speeds by using only the white dot. With the red dot I can get none.
Erik.
We will see ...
Erik.
As you know, I make winding/speed knob by myself. I don't have white dot. I have open central part of the knob, I can see there is speed pin selector go. For sport group it has 3 notches, 100, 200, 500/1000 last one "sheering" by some separator. This is only working notches (speed) in my Contex. If I need select a speed I put the speed pin in one of those notches. Interesting what 1/100 notch (or white dot) working in all groups and give me 1/2, 1/5, 1/25, if I need 1/50 just move pin into 1/200 notch in "normal" group. Sound a little complicated, but it not. Just select 1/100 and only change the group if need a slower speed. However 1/200 and 1/500 and 1/1000 works in same way and giving additional 12 speed combination 🙂
Yes, this sharing works via a small steel pin, attached to a ring through wich the big steel screw goes. Attached to it is a small spring that pulls the separator to the side. I've lost this spring. It just sprang away. I can't find it anymore, but I don't care, as the difference between 1/500 and 1/1000 is only a fraction of a millimeter of the slit with. After 85 years or so this precision is no longer there.
Erik.
