CV 40/1.4 and 43->55 step up vignetting?
Shouldn't be a problem, but may interfere with the viewfinder.
You must already have a pile of 55mm filters?
If you don't mind a guess, I'd say it probably wouldn't be a problem. I can imagine the relevant dimensions to be similar to the 40's own lens hood.
Jeremy
I just got the ring. Its actually not too bad as far as blocking the VF. It does block the corner 40mm marker but thats about it. Plenty fine for composition.
