Well, I messed something up. Let me explain what I did and maybe someone can see where I went wrong.
I went by my local camera shop and picked up a small bottle of HC110 concentrate (Roger, I looked for the ones you recommended but this was the only developer they had, besides D76 and Rodinal). I didn't want to mix up a whole 1/2 gal of stock (since this might be the only roll I develop in HC110). So I did the math and concluded that 10 oz of working solution of dilution B equals 0.31 oz of concentrate + 9.69 oz of water, as follows:
stock = 1 part concentrate + 3 parts water
dilution B = 1 part stock + 7 parts water
so
10 oz dilution B
= 1.25 oz stock + 8.75 oz water
= (0.31 oz concentrate + 0.94 oz. water) + 8.75 oz water
= 0.31oz concentrate + 9.69 oz water
Which I converted to ml as 9.2 ml concentrate + 286 ml water. I used a syringe and measuring cup to mix 10 oz of dilution B. Then I looked up the developing time at the Massive Dev Chart (11 minutes). The developer temperature was 69F, but I suspected I might have slightly underexposed the pics, so I stuck with 11 minutes. I developed the film using the procedure I use for D76 and Rodinal: soak, developer (agitate 30 sec then 5 sec every 30 sec), stop, fix, wash, permawash, wash, PhotoFlo. This was in a Patterson two-reel tank, with the loaded reel on the bottom and an empty reel on top.
Seems okay? Well, the negatives are almost clear. I can see just a hint of the images. It seems like I've grossly underdeveloped the negatives.
I'm pretty sure I didn't massively underexpose the pics, because I was shooting in a medium-lit pub using 1/60 at f1.4 to f2.8 while rating the film at 1600ASA. Also there were a couple of outdoor shots at 1/250 f5.6 or something like that. I also am pretty sure the camera didn't malfunction, because I put a roll through it last week and all the combinations of shutter/aperture worked fine.
I wonder if I didn't mix the dilution B thoroughly enough. But wouldn't all that agitation complete the mixing, so that at least some parts of the negative would be developed?
This is no big deal - just pics of some guys and gals at beers - but I'd like to know what I did wrong. Any ideas?
