Did I overpay? Komura 100mm/3.5 LTM
Interesting Johan. Mine vignettes more than that. Perhaps I had not put the hood on correctly in the test images I took.
Well, while scanning now I have found out that its FOV is very wide and since its such a compact lens, you really need to get your fingers out of the way. I'm forced to cut off a lot of fingers 😉 in corners.
Maybe the lens hood just gets in the way on several apertures. Also, mounting a filter first and the hood on top of that might make the hood protrude too much.
But, this is all guessing with me.I'm shooting this without the hood, the seller gave me a discount when he found out he had misplaced it with the original leather case... Luckily the finder was included, as well as a non-branded deeper rear cap which might be original. The finish of lens and cap is very close, at least.
I'm very pleased with this lens, and with the 35mm W.Acall Kyoei I own. In fact, I'm selling my M-Hexanon 35mm f2.0 because it's a shelf sitter since the Kyoei arrived.
@ Raid: thanks for your comment!🙂
Chris,
The infinity focus is not alligned in the RF patch. I may get the lens adjusted to achiever higher levels of sharpness.
So I read that on testing the infinite focus and tried out my "soft" Elmar. (Learn something new everyday). It seems to be misaligned when I do that on the Bessa R, but it seems to be aligned properly on my M3. I'm pretty sure the Bessa is not horizontally misaligned, because I've focused it well with my 50/1.5, wideopen.
I have a similar problem; the lens does not allign on one Canon P but is much better alligned on another Canon P. My other lenses work well with both cameras. 😕
full shot and crop from the W.Komura 28mm f3.5
Shot at Prachovské Skaly, Czech Republic, using Leica M5 and W.Komura 28mm f3.5 lens. Kodacolor 200ASA, f11.0 and 250th. Full size shot, raw scan, saved as JPEG:
The crop 100 % looks like this:
the sticks are kids jokes, they give the impression theses are needed to keep the rock upright. Actually, they might be necessary someday, since the whole base of this humonguous big rock measured no more than 3 by 6 meters.
Johan,
Your posted image is huge! The sharpness of the lens is there.
This will definitely be a one-of kingsize post, Raid, it is huge, I agree. But, like you said, it shows sharpness is there!
From now on, people will just have to take my word on it with the smaller image😉
I'm still keeping an eye out for a Komura like yours, and would like to know the 'solution' to the inconclusive rf-coupling mystery on your Canon bodies!
Johan,
I will have the lens looked at by Eddy Smolov in the very near future. I always have stuff for him to inspect for me. Throwing in the Komura lens will not add much to the weight of the parcel.
Here are a few new images taken with the Komura 105mm 3.5. I cropped here and there.
1. Lina at Starbucks
2. My wife
3. Dana
Thanks, Brian. She has my brown eyes. I mean,she has the same exact color. We all have brown eyes on both sides of the family.
Paid $20 (or $25?) for a Komura 105/2,8 last year. Clean and on-the-dot. Focuses right on, and couples with the RF. It's neither light nor compact though. Sized, and weighs, about the same as a typical 105mm SLR lens from the late 1960s.
Studio photo with the Komura 105, mounted on a Leica IIIf:
Strobe lighting on colour negative film.
This is very nice image.
Your Komura for $20 was a super bargain.
Spending $125 on the Komura 105/3.5 isn't overpaying. Here's why:
I needed a lightweight "telephoto" lens for traveling, so I picked up both the Canon 100/3.5 and the Komura 105/3.5 and compared them against a postwar Elmar 90/4. I'd figure I'd compare the lenses and keep my favorite.
I was surprised by the performance quality of the Komura. I find the performance to be almost indistinguishable from the Canon 100/3.5.
All three lenses gave very similar results at mid aperature (f/8) at infiniti. At a closer distance (about 20 feet) the Elmar noticeably underperformed (seemed to suffer from flare).
At wider apertures, the Komura may suffer from some dropoff in sharpness at the corners wide open, but I'd have to do more tests to know whether this was just depth of field issue.
The Elmar (200 g) and the Canon (182 g) are roughly the same size and weight. The Komura is noticeably larger (about 30%) but it isn't much heavier. I don't have a scale but I'd guess about 260 g, whereas the earlier Serenar 100/4 is 460g.
A postwar Elmar seems to go for about $90 and Canon 100/3.5 is about $170. Since the Komura is opitcally extremely close to the Canon and only larger, I think the price should be close to that of the Canon.
A do plan on adding a full review with photos to my new blog.
I have the same lens branded as KYOEI ACALL. Probably this small company was merged into KOMURA in the 1960's.
I've used it in Color and B&W and it's sharp and show nice colors.
cheers, Frank
I used to own the 105/3.5 Kyoei Acall, and it was a decent lens. Sharp images and good with color, as noted by Sonnar2. Put it on eBay, and it sold for about $225.
