Calzone
Gear Whore #1
- Local time
- 12:35 PM
- Joined
- Nov 11, 2008
- Messages
- 16,953
- Location
- The Gateway To The Hudson Highlands
Glad I own my Tower 45/46. Otherwise I'd have some major GAS.
Cal
Cal
Thanks for the nice words.
It's funny; none of the cameras/lenses are rare/collectible/valuable yet at the same I find it to be an interesting bunch nonetheless.
I've just ordered a Canon 'hood for the 50mm f1.8 and it seems to be clip-on version with tightening screw. Is that 'normal'? I ask because the filter thread dosesn't seem to be the standard 40.5mm that I expected. But perhaps I should ask in the Canon LTM sub-forum...
I'll probably have more questions in the coming weeks/months in any case!
Pip.
Thank you very much for the compliment, dourbalistar, re: the bunch and even more so for the info you added. I believe you will be seen to be correct once the package arrives. The 40mm thread-size (which comes as a slight surprise to me!) also makes sense and, unfortunately, my naïveté is showing!...I'm not sure the hood you ordered will fit your chrome Serenar lens......The Serenar 50/1.8 has 40mm filter threads, so perhaps 3rd party screw-in hood would work.
I'll have to have a second look at the link, dourbalistar. It is entirely possible that the cased set which I bought contains the hood-unit and the adapter which were already screwed together to form the unit which clamps over the lens barrel....I believe you want the Canon Series VI adapter and hood...
Those Canons tend to have boomerang haze. 🙂
I sent my Nicca type -3 MIOJ and some barnacks to Popflash for service. Super quick, they have an old-school tech who is retired but still loves to work on the old cameras. Might want to talk to Tony Rose at Popflash about those shutters.
The adapter part into which the hood screws has the engraving '42mm' which, obviously, marries-in with the exterior barrel dimension.
Thanks again for your input.
Pip.
Hmmm....not quite.Is there a "S-42" engraving on your hood? If so, you may have the 42mm version of this clamp on hood, which I think was designed for the later black barrel 50/1.8 LTM lenses...
Hmmm....not quite.
Nor does what I have look quite the same as any of the groups in the links. Similar but not identical.
Here are a couple of (very bad I'm sorry to admit) snaps which show the two parts I received;
Pip.
The ring is certainly of Canon manufacture as seen here;...Perhaps you have a series filter adapter from a different brand, mismatched with a Canon hood?
Either way, it seems to fit just fine...
As you say; the important thing is that, through my good fortune, it was the correct model for the job in hand.
Pip.
I have created a website covering all the Canon rangefinders 1935-1968 and Canon rangefinder lenses. Also there is coverage of Nicca, and pages on all the Minolta-35 cameras and their lenses. Also some other M39 rangefinders (Reid, etc.)
https://www.canonrangefinder.org/index.htm
perhaps have a look... Larry Huffman huffman@gmx.com
