ampguy
Does anyone know if there are diopters available for CL's in the ~ -2 range?
ampguy said:Does anyone know if there are diopters available for CL's in the ~ -2 range?
Palaeoboy said:Leica did make diopters for the CL but they are no longer available new. They rarely come up for sale as well, I have only ever seen 2 in my life. The chances of then getting a specific diopter makes it even more out of reach. Sorry!
ampguy said:Joe, if you wear glasses to read close, or to see things near, you may benefit from a negative diopter though some negative is built into your M's and SLR's by default.
If you can read and see fine close without, but need glasses to see clearly in the distance, you might benefit from a positive diopter.
If you have astigmatism (rotated eye errors), it is best to wear glasses, to my knowledge, there are no diopters that can correct for astigmatism.
back alley said:i wear tri focals.
Andrew Touchon said:I think you may have your positive and negative discription backwards. I am near-sighted and my prescriptions are negative diopters for distant vision. When you get old have problems reading close up, you use a positive diopter lens, which is a magnifying glass.
