Does the digital CL feel like a "real" Leica?
Regarding M mount lenses and others, just about anything is possible with the correct adaptor. I think of manual focus lenses on the CL as a bit of fun. Best by far to use native lenses. Whilst the argument over crop factor goes against wide angle lenses, it works in favour of longer focal lengths. My 200/4 OM makes a very handy 300/4 at negligible cost.
Regards
John
John,
Plus one. Longer lenses do very well. In my case a Noct-Nikkor and 50 Lux-R make truly great short fast telephotos. The crop factor utilizes only the sweet spot for high IQ.
Cal
Also no internal stabilisation - which should make using MF lenses more difficult.
No Phase Detect and dust clean, either. While dust clean is available for ten+ years already.
So, CL does feel like true Leica, because it is hard to image any other manufacturing without sensor dust clean. I mean, regular cameras manufacturer.
Dust bunnies is Leica sensor unique signature. It is so M-E. 😀 Joy of M lenses at its poor experience. Oh, wait M-E has shutter in front of the sensor. CL - full dust exposées.
On the positive note, I opened BH mirrorless page sorted from rich to just working.
Here is how first pages top $$$$ cameras looks like:
M10 - nice.
Sony something - ugly.
M240 - nice.
Panasonic something - ugly.
Fuji something - ugly.
CL - so cute.
CL is for Cute Leica.
https://tenor.com/view/give-me-gif-6484587
Leica M is what makes a Leica. The rest are just expensive cameras.
Mirrorless should be tried b/4 buying. There is a refresh lag between what the lens sees and eyepiece which is very difficult to me. Ok for landscape and subjects that do not move, well sort of, but impossible to time sports or dance shots. That is why they fire off 10 frames trying to get one good.
I get pretty much the same amount of dust bunnies on Leica and Sony despite the latter having a bunny shaker. Still, it's a feature that is sometimes actually useful, and Leica definitely should try to find a way to adopt it this century.
How do you find the 35TL? It looks like a gorgeous lens, but somewhat on the bulky side. I'm intrigued, but since I'm used to my X100F and G2, a lens that size seems like it would make the camera more of a pain to carry, and less stealthy when I'm taking candids.
The 35 TL Summilux is not a whole lot bigger than the 18-56 so it’s not difficult to get used to.
The lens rendering is very neutral wide open, which where I use it 90% of be time.
Bokeh is smooth both in front of and behind the plane of focus.
CA around bright light sources seems fully corrected.
However, I do still prefer the M 28mm/2 for angle of view and size when walking about town, so my 35TL usage has mostly been indoors.
The 18-56 I’ve found ideal when hillwalking or for grab shots from the car when pulled over by the side of the road.
FIT,
The CL with a 28 Cron-M is a 42mm. Two clicks on the right dial and I get the magnification I need to focus fast and accurately. At tap on the shutter and I get full framing.
Rigged with a 28 Cron it is very much like a film CL with a 40 Cron. Also is sized like a LTM IMHO.
What makes the CL a great camera is that it is fun and easy to use.
BTW the 28 Cron with the limited scalloped metal hood looks evil on the CL.
Cal
Yes great lens, seeing more use on the CL than it did on the M.
With the CL EVF/LCD seeing flare is easy, so I go for compact and do not use a hood instead use my hand as a shade when needed.
Anyone that would need image stabilization on a camera that can shoot at iso 12000 must have some crazy shakes.
I believe what cameras with similar 400 and 12800 ISO do not exist.
I'd rather use IBIS or IS, f8 , not amplified, low ISO and hint of flash to balance 1/30 with ambient light.
A'm this shaky?
A 42 WOULD be awfully close to the 45 AOV I love so much on my Contax G2. Sounds like a great day-to-day shooting lens.
The Contax/Zeiss 45mm Planar G is further from 42mm than would appear going by the nominal focal length, as it's actually more like 47mm according to the specs...
Focal length: 46.9mm
Angle of View 50 Degrees
Elements/Groups 6/4
Dimensions 56 x 38.5mm (2.2 x 1.52 in)
Film-to-flange distance 29mm
Weight 190g (6.7 oz)
Filter Size 46mm
f/Stop Range 2.0 to 16
Minimum Focus Distance 0.5m (1.7 ft, 20 in)
Specs show abt 1% barrel distortion.
This thread might point to the unmet demand for a full frame M-mount camera with a rangefinder-style EVF. Beside the mechanical simplicity, it would probably sell in greater volume and cost less as a result.
Yes, agree. I use a CL because there isn’t a sufficiently compact full frame EVF M camera for my needs.
Hello Mike ... 😀
Sort of the same here. And for me it is not a bad replacement for the Q. the 2/23 focuses fast enough. Other lenses are happily adaptable and the package is small, when used with MF lenses of reasonable size.
With respective adapter it is a nice companion to a film camera, if the crop factor is not killing it.
Hello Mike ... 😀
Thanks again for the lovely lens! 🙂
Fine recap of the CL’s utility. Similarly pleased with mine, happy to pay the Leica premium for a body that plays better than other makers’ crop mirrorless alternatives because the CL plays so much better with M glass.
