jrong said:
So it doesn't matter what you rate your film at, the dev times are 3-4 mins minimum in A and B each?
It does not seem logical, does it? After all, if you bake a cake, it is done after a certain period of time. If you continue to bake it, it burns. Bake it long enough, and the fire department comes to see you.
Standard development is like that. You don't develop enough or you develop for too long, and you get results that are not happy.
But Diafine (and most two-solution developers) don't work that way.
Most developing agents (one of the chemicals in typical developer solutions) are terribly, terribly slow. If you used them by themselves, it would take years for your film to develop. So, an accellerant is added, which makes the developer go loco on the film. In fact, it goes so loco that a buffer and sometimes a retardant have to be added - in precise proportions so that the film is fully processed - for shadows, midtones, and highlights - at about the same time for a given temperature and dilution.
In those cases, the developer has to be kept moving - agitation moves exhausted developer away from contact with the film emulsion and moves fresh developer in. That's why inversion and agitation are called for with most standard development.
Diafine instead breaks down the chemistry so that solution A has just the developer in it. This is absorbed by the film when you soak it for three minutes (you can soak it longer, but once a sponge is full, it is full, and emulsion is a very thin sponge on the surface of the film base).
When you pour solution A back out of the tank, that portion which was absorbed by the film emulsion is still there, waiting to be activated.
Solution B contains the other half of the developer - the accellerant and etc. When you pour it in, it combines with the developer that has been absorbed into the film emulsion and begins to attack like crazy, turning silver halide into metallic silver as appropriate. But when the absorbed developer is exhausted, development stops. No need to worry about the time, once it is done, it is done. There is nothing left for the accellerator to accellerate. This usually happens in 3 minutes.
That's where we get the 3 minutes plus 3 minutes thing. And that's why it is always the same no matter what speed you shot the film at, or what it was rated for. When the developer that's been absorbed into the emulsion is all exhausted, development is over. So the cake can never get overbaked.
This also means that Diafine keeps nearly forever in the bottle. You reuse it, pouring both solution A and solution B back into their respective bottles after each use. Solution A will slowly go down - some is being used by each roll of film and you don't get that back, but Solution B will stay the same level, more or less. And since the developer is not 'active' in the bottle by being mixed with accellerant, it does not break down in the presence of air nearly as much as most one-solution developers, which often have a limited shelf life.
The downsides are these:
1) Diafine gives a speed increase to everything. How much differs, but it is always there. Hard to shoot film at the rated speed, so if you intended to shoot slow film, you might not be able to with Diafine.
2) Since everything is fully developed always, there is no such thing as 'pushing' or 'pulling' film by intentionally over or underdeveloping in Diafine as you can with other developers. Some folks pull the film out of solution B earlier, but that's a bit dicey for most of us.
I hope this lengthy response helps!
Best Regards,
Bill Mattocks
