I have an epson 4990 and yes you can, you can just put the nagative flat on the scanner and scan up to a4 size negatives if you like. There is a "film guide" wich is basically a huge empty square so you can scan up to a4. Thats what I use to scan 4*5 negatives without loosing 5% of the edges like with the standard film holder.
I have an epson 4990 and yes you can, you can just put the negative flat on the scanner and scan up to a4 size negatives if you like. There is a "film guide" wich is basically a huge empty square so you can scan up to a4. Thats what I use to scan 4*5 negatives without loosing 5% of the edges like with the standard film holder.
