Rayt
Nonplayer Character
What this means is an additional $60 to send my film back from a trip by courier. I can’t rely on the possibility of getting a hand check.
IMG_3469Boston's Logan Airport is reportedly one of the airports at which the TSA is testing new CT scanners. Does anyone happen to know which checkpoints have the CT scanners? I flew out of Logan's Terminal E in December and used the trip as an opportunity to conduct a casual test with a roll of HP5+. I shot ten frames of the same scene. Then I clipped half the roll and took it with me, leaving the other half at home. The strip I took with me was scanned twice: once at Logan Terminal E, and once at the airport in Wrocław, Poland. Yesterday I developed both strips in the same tank. Below you see both strips on the light table. I can detect no difference between the two. For what it's worth, the top one is the one that was scanned.
Does anyone know if the new CT scanner(s) at Logan are labeled as such? I did not see any sign indicating that new technology was in use--my bag may well have passed through a standard X-Ray scanner. So I cannot offer this test as a demonstration of the effects of the new equipment.
The new scanners are not labelled as such but you’ll know it when you see it. It looks like a hospital MRI scanner with the round opening. Travelers do not need to remove their laptops etc like for older scanners.
A TSA supervisor told me that the newer machines are supposedly safe for several passes with 800 and below film. I recently took a roll of Cinestill 800t two ways via air and it showed no fog, streaks, or whatever.
What does concern me are the times when your bag goes through the scanner and the agent can't identify something. He/she will rock the belt back and forth (I assume with tbe beam on), then maybe call over a supervisor or cohort, and they sit there and point and rock the belt back and forth and nod at each other and I assume my film is getting a continuous soaking.
Pretty much everywhere by now. They are not being tested, they are replacing all older models at all airports.Boston's Logan Airport is reportedly one of the airports at which the TSA is testing new CT scanners. Does anyone happen to know which checkpoints have the CT scanners?
image2 by ray tai, on Flickrimage2 by ray tai, on Flickr
I let a box of 4x5 TMX go through the new scanner at SFO because I didn't want to risk a hand check where the TSA would inevitably ask me to open the box! This is one of the shots. It was shot with a pinhole Walker 4x5. Can anyone see any ill effects from the scan? Some of the other negs came out "blotchy" I guess because it is a pin hole? Xray damage would be a wave effect?
Yikes. Luckily they weren’t using the new machines when I went through JFK (the terminal o went through had one but it wasn’t in use) but I asked TSA to hand check my film (35mm, 120, 4x5, and 8x10) so at least there’s a way around that. What worries me is when LHR gets the new machines, they simply refuse to hand check any film at all. Might have to switch to digital which isn’t a big deal for my 35mm kit since it’s pretty much a 1:1 replacement (M10 instead of the M4), but if I want to fly with my Rollei or 4x5 kit? I know several photographers who shoot 6x7 professionally who’ll have to drastically change their workflow (I.e procure film and develop at the location) if provisions aren’t made for film.
I would play it safe and use film plus digital.
