Filter question
I just shot a roll of Trix outdoors with an ND 4 filter on it. Whoops. Never used an ND filter B/W film. What should I expect?
ND filters are used to control light levels to reduce exposure either to use slower shutter speeds or larger apertures.
Finder, I get it...
I wrote "With handheld meter or guessing exposure, you give the film two stops less light than required...", but you decided to read "With handheld meter or guessing exposure, you should give the film two stops less light than required...
Juan
Like Carter, I wonder why a neutral density filter would reduce the contrast. I think the main use of a ND is so that you can use a larger aperture in bright light (to reduce the depth of field) or to slow the shutter speed (to allow fill flash in daylight.)
As far as I know it doesn't affect the tonal range of the film.
I've had some problems with ND filters and flash, it always seems that I have to fight to get the shutter speed down and/or the aperture more open and then the flash is still not in the fill range (maybe I have to rethink this)(in theory you are right but I continue to have problems). So, I gave up on ND filters (with flash) and try to use leaf shutters with my (fill) flash. Oh well, maybe I'm just not getting it.
