Update: I stopped using the first set of baths after developing the 29th roll. Most developed films were 200 ASA, one 100, one 400.
The examples are from the last film.
I am reviving this thread with a question. It seems through your findings, that youcan easily develop double the amount of film with good results. But how are those negs holding up a couple of years later? I am particularly interested to know about the few last rolls developed from a kit. Are they any darker than the first rolls? If the stabilizer was weak I would think that the film would keep cooking.
I am ordering my first C41 kit soon and would like to know how far I can go with it. Have anyone tried replenishing the blix or stabilizer? Is that possible?
Yes, diluted chemicals, mixed and stored in black containers with little air above. I had expected blank negatives or way bigger color aberrations.
My tank takes 600 ml for two reels, so I am trying this: I divided the 1 liter volumes of developer and blix into 600 + 400 ml, the 400 kept aside as a replenisher of sorts. I had planned on eventually throwing out 400 ml of the used developer and blix and replacing with the "fresh" stuff.
I will probably do that after 15-20 rolls (hey, given Petronius' data, maybe the limit is 40!)
Randy
Your comment about "diluted" has caught my attention. Did you mix the chemicals differently from the recommendations of Tetenal Instructions?
they suggest
1000 ml of water including the Developer chemicals
1000 ml of water including the Blix A and B
1000 ml of water including the Stabilizer
what "dilutions" did you use to store the chemicals?
Did you just add water to top up the containers to 1000 ml after running the film thru the process and then store?
Or did you add water to have dilutions in excess of 1000 ml of solutions?
I am not sure if this will bring you more developed rolls. It is the one liter solution that will give you your total amount of rolls, so just pouring the used chemicals back into the fresh after every developing will give the same result.
The film might look good and OK now, but how does it look after several years in archive? My guess is, that it will be darker than the rolls developed in fresher chems.
