Terence T
Where'd my Bessa go?
Is there one available? Been looking but can't seem to find any info.
jaapv
RFF Sponsoring Member.
As far as I know this simply doesn't exist. It is more SLR terrirory, I would say. There are (used to be?) screw-in fisheye-converters that might work. There are no viewfinders for that, however.
Roger Hicks
Nikon-to-Leica adapters are quite common; they are not expensive to have made. Mine was by SRB of Luton. Then use any Nikon-fit fisheye. For a viewfinder, try a door viewer. Or guess.
Roger
Roger
Terence T
Thanks guys. I'm aware of the Nikon adapters but thought there might be a chance that a dedicated M or LTM fisheye would be available. Will probably pick up the Nikon adapter.
Lonius Funk
I have a rokkor Fisheye for Minolta..if you find an adapter then I can sell you it.. if interested
Terence T
Thanks, I'd keep that in mind.
gc1
Terence T said:Is there one available? Been looking but can't seem to find any info.
This guy is selling a russian fisheye 16mm zenitar. http://forums.clubsnap.org/showthread.php?t=143055
I'm not too sure about how's the quality of the lens but worth a look if you're interested.
Mackinaw
Think Different
You can mount either one of the Canon FD fisheyes (7.5mm circular) or 15mm (full frame) on a Leica LTM by using Canon's lens mount converter B. Combine that with a LTM to M adaptor, and you can then mount these lenses on a Leica M.
Jim Bielecki
Jim Bielecki
radi(c)al_cam
@jusxusfanatic, re «Fisheye lens for my iii»
Since you love to eliminate your threads although people have given you serious and helpful answers, I suggest: Read this thread here.
radi(c)al_cam
You did it again!
[NEW, ready for elimination I presume, thread: http://www.rangefinderforum.com/forums/showthread.php?t=160038]
Canon FD 7.5/5.6 VS Rokinon 7.5/3.5 for my iii
Fine.
Yes I know I need an adapter.
Good.
Are they rangefinder coupled?
No.
And where can I find a viewfinder for it?
See above, 08-02-2005 18:56 CET.
Thanks![]()
Welcome.
jusxusfanatic
Yea... ��
Not RF coupled?
Not RF coupled?
jusxusfanatic
Ohh a door viewer!
Graybeard
Longtime IIIf User
The 16mm Zenitar M42 mount with an M42/LTM adaptor works well on a Barnack Leica; I've used this for some time now. Presumably ithis would work as well on an M Leica by adding an M/LTM adaptor.
As was suggested by an earlier contributor, I use a (Home Depot) fisheye door peephole, masked with black tape, as a viewfinder.
JMQ
See Stephen's link to the Voigtlander 12mm or 15 mm below. I don't believe they are RF-coupled. The only one I know that is RF-coupled is the canon 19mm f3.5 in LTM.
https://cameraquest.com/voigtlenchart.htm
jusxusfanatic
So the 7.5mm is basically not useable on my iii?
radi(c)al_cam
It is not «not useable» [sic], if you accept certain limitations; Raid gave you a completely correct answer:
The Canon FD is obviously in FD mount. You need Canon Adapter B FD to LTM, and also an adapter for LTM-M. No, it is not rangefinder coupled. The depth of field is enormous with this lens. It is a circular fisheye lens.
