Focusing Issues
Joe Mondello
Resu Deretsiger
1:27 AM
Manhattan
OK, I took my R-D1 out for a little night shooting in Times Square last night and noticed a few things on my return, sad to say . . .
1. Back-focusing. I've heard about this on AF cameras but It seems clear that the focus point is behind what I actually focus on -- at least within about 3-5 meters.
2. Infinity. The rangefinder doesn't seem to focus to infinity as the images never align. However, the images themselves look sharp.
I'll probably do a more thorough test over the weekend.
So I guess my questions are these . . . Is this a function of misalignment in the camera or is it a function of the lens?
Since at the moment I only have the 40mm Nokton to try (the 15mm has it's own finder of course) I wasn't sure if this was a lens or camera issue.
OK, I also see the "vertical adjustment" thing is off a tiny bit, probably not a big enough deal to send off for on its own. The actual focusing issues though are another thing altogether.
If I understand you, I believe issue 2 to be fixed with adjustment for Infinity.
As I understand that will also influence on the back focus problem
You can try to adjust it yourself or send it to Epson or DAG
Thanks, Jarle.
I could try to adjust it myself given instructions. Do you know of any for adjusting INF focus? Is it the same set of instructions for the vertical alignment thing?
I sent mine back to Epson for the same Rear Focussing thing, the 28 Ultron was unusable at F5.6 which was funny as I didn`t notice it as much with the 35 F2.5 PC - the loaner focusses all lenses bang on, I`m hoping that they can get aligned as well as the loaner
Same
Same
I'm finding that my refurb R-D1 also needs infnity focus adjustment. Backfocus I can't judge yet,but it also appears to be a problem with some images. Samples form today:
http://www.pbase.com/scho/rd1
endustry said:
I received the following quote from DAG regarding rangefinder allignment:
"Aaron,
if the R/F is an easy fix the cost is $40.00 plus return shipping, if
the
repair involves additional work to the R/F then the cost would be
$80.00,
regards,
Don
DAG"
Wow that's really reasonable.
Did he quote a turn-around time?
Now that I have 3 lenses I'm going to make some tests over the weekend to be more certain that it's not my error, but an actual fault in the camera.
