Found a "wartime" 135mm f4.0 Carl Zeiss Sonnar in LTM!
I don’t suppose it’s m39/Ltm? The rotating front on the contax RF mount is a problem for me. The Leica version is fixed and hunting far a wide for one.
Yes it's LTM, I'll have to pull it out and let you know! Been awhile since I last used it! Actually received an LTM Elmar 135 and thought about comparing!
Hello. New here. Resurrecting this thread in the hope to find out a little more about this lens. Can you tell me please if the front (including the filter ring / front element / nameplate stays fixed as you adjust/turn the focus ring, or does it rotate as well, as per the Contax-RF mount version. ie. would variable polarizing filters and gradient filters remain vertical if used?
Would you be willing to sell this lens if you still have it? I’m unable to DM you - perhaps because I just signed up and have not yet posted. Thank you!
Johannielscom died years ago here but caninemoshpit lives. And I happened to stumble onto RFF just tonight, for the first time in several months I reckon...
I sold that lens long time ago and have since bought another one. Those 135mm wartime Sonnar lenses have become slightly less cheap, let's keep it at that.
And no, I'm not selling this one. And yes, the aperture mark and name plate and filter thread remain stationary when you focus the lens.
If it's filters you want to use, just get any SLR with a 135mm lens, it surely isn't that you nééd a Sonnar design 135mm lens to shoot your stuff, haha.
Fab. I’d been keen to see the comparison if it happens. I’m not so familiar with the Elmar’s but was these post war CZJs lenses are on my radar. Their Sonnar charm, subtle coating (flaring opportunities), and extreme blade count (circular highlight perfection) are an ideal for my video work. Truth be known - I clamp an anamorphic adapter on the front of my primes, hence the need for constant vertical alignment and LTM mount. All going well I’m interested buying it. Check you DMs 🙂
RIP Johannielscom and his lens. Pleased you’ve both reincarnated into new forms. I agree that the “need” for 135 wartime glass is not crucial to anyones existence, but desire is a strong force! Ha! Do you have any photos taken with either one you can share?
Not super scientific, all handheld but the Sonnar is sharp! Only mostly lacks contrast to the Elmar. Another negative for the Sonnar is close focus only 2.5m, to Elmar 1.5m. You are correct front doesn't rotate with focus.
Thanks for sharing analoged. The Sonnar is indeed sharp (more so than the 135 triotar I’m looking to replace), and the bokeh very pleasant even stopped down. The 2.5M MFD is extreme! Do you know why this is the case with the Leica mount variant? From what I gather the contaxt-RF mounts have a much more usable 1.5M?
A lot of the war-time LTM lenses have more strict near focal distances than their Contax mount equivalents. This is true for the 85/2 LTM as well where the NFD is 1.8 meters. There are transition and one off lenses that focus closer, but as designed by CZJ 1.8 meter was the limit. Even the 5cm Sonnars "only" go down to the LTM spec of 1 meter VS a sliver under 0.9meters as per the Contax.
One reason may be simply have been that they did not trust the Barnack Leica (which you have to remember was the only game in town then, no M system or even the later Barnacks) rangefinder to be accurate enough, or perhaps they simply wanted a moat between their rivals system (which Nazi high command forced them to make lenses for) and their own.
There is of course the counter-argument of the 28/8 which I also have - which has rangefinder coupling on the Leica, but not on the Contax.
There are also mechanical reasons. On my 135/4 LTM Wartime Sonnar the helical already runs near the length of the lens. Extending the NFD out would have required to either change the construction or to lengthen the lens body, either of which may have been deemed unacceptable. The 85/2 Sonnar had a bit more leeway.
We can see this in the Jupiter-11 which unlike the Jupiter-9 does not extend the NFD, which stays at 2.5 meters.
The Contax, with its helical and linkage inside of the body is not affected by this.
An external mount lenses just needs its own helical - so you can use all the space which would be otherwise required for the intermediate translation helical to 51.6mm. Some hacked lenses circumvent that by using a sloped cam.
