elude
Some photographer
I feel the same. That's probably why I don't share online photos but homemade wet prints .
I too had given up on scanning traditional BW film, and that was long ago.
The only film, to me, that really scan and yet can be printed nicely in the darkroom is XP2.
Nowadays I do only wet prints, and I scan the prints just for web use.
IMO, in order to achieve the full potential of film, one has to use traditional darkroom printing methods. This takes some skill. Just as scanning/post processing does in the digital realm. If one does not have either of these abilities in adequate amounts, and one lacks the perseverance or potential to develop these skills, then pursuing an alternate process is understandable. My point is that the fault lies in you, rather than a process you are not be successful with. Sorry, that may be harsh, but it is the way it is, IMO.
Roger Hicks Quote:
Seconded. Every now and then I scan negs for articles, and XP2 is so far and away the best for scanning that there's no competition. But I still vastly prefer wet prints for B+W. Although 8x10 negs can be scanned quite satisfactorily...
taxi38 Rem,youve answered youre own question,Sean Reid tackled this very question and concluded that its a question of scanner resolution,it needs to be high enough not to suffer this "resonance"or whatever it is that causes this apparent clumping.I use a minolta 5400 mk1 scanner and do not suffer this ailment,....you can only buy second-hand but is cheap for what you get.
I have concluded that, for me, 35mm scans just lead to so much disappointment that it's not worth the time and effort. If I produce nice images from now on, I will print a wet print and scan that.
I am now also shooting 4x5, and those scans (and 120 film) are superb.
Film is for silver, digital is for digital - pressing one to conform to the other, whether it's scanning silver negatives or positives or wet printing film bubble printed from digital, will bring out the difference. Silver is chaos, digital is a gridiron of pixels. Accepting the limitations and advantage of one, the other or a mix, each with its peculiar characteristics, has expanded our wonderful world of photography. As I see it, remegius's problem is his scanner. Flat bed scanners (FBS) are made to digitize pieces of paper with images of fairly low resolution lying as flat as possible on the scanner glass. While the do have some impressive depth of field to their tiny lenses, flat bed scanners try their best to make a "pleasant" image. However, most OEM film holders for FBS are bad at holding film flat and most software very good at trying to reduce noise. To the point where grain in shadows just dies. Vue Scan and variable height film holders with anti newton ring glass to hold film flat help a lot, but dedicated film scanners do a much better job. After all they are made to scan film, not paper. There is a simple comparison here of results from an Epson 4990 and a Microtek ArtixScan 120tf: http://abdallah.hiof.no/photography/4990-artixscan/. (Note that the epson is using both its OEM film and a jury rigged flat ANR glass holder.) The FBS is quick and easy to use, the film scanner is excruciatingly slow and terrifying loud, neither smells, my fingers don't prune up, they don't bother my eczema and don't have me hidden away in a dark room (with someone outside wanting to use the bath) for hours on end. My compromise is the Epson FBS with variable height film holder with ANR glass and Vue Scan set for medium format and up. The ArtixScan is fired up for 135 and 8x11mm negatives.
- Børre
Myself, I came back home 2.5 years ago. Left home for digital, went hybrid now fully analog again.
I can't figure out how to post pictures here but go over to my google website and check out the folder labeled SPENCER. Taken this weekend with Arista Premium 400, developed in Ilford ID-11 1:1 and scanned with a Dimage Dual Scan. No retouching. Do you find the grain in these photos objectionable?
http://picasaweb.google.com/113091145775152549903/Spencer#
I can't do that in a darkroom, and I can't do it with a digital camera, so?
