How to Think About Color Filters for B&W
bmattock
2:17 AM
Detroit Area
Another Way to Look at Color Filters
I think we tend to get confused about the use of color filters for B&W because the descriptions we read don't address some underlying assumptions which are incorrect. So I was trying to think of a way to present an explanation of color filters that makes sense. This explanation assumes properly-exposed and developed film to begin with.
I think the basic problem is that we think of B&W film as if it were just 'desaturated' color film, and it is not. Color prints say that white things are white - black things are black. Blue is blue, and so on. Is this not also true of B&W film, at least for the 'white' and 'black' things?
B&W film does not record black as black and white as white. What? That's right, B&W film does not know what white is, or what black is. It records only shades of gray based on a sliding scale of relative brightness. Everything is on a sliding scale of relative brightness - the brightest is white, the darkest is black. Everything else is a shade of gray.
What I mean by that is this - in any scene, B&W film records the lightest shade present as 'white' and the darkest as 'black'. Everything else gets a shade of gray, based on it's relative brightness compared to everything else in the scene.
Now, knowing this - if we use a color filter to increase the RELATIVE brightness of a particular color, then everything of that color gets bumped up the scale of relative brightness - it becomes 'lighter' in shade. If it becomes the brightest light in a scene we're photographing, then it gets recorded as white.
The film is recording LUMINANCE, not B&W RENDITIONS OF SHADES OF GRAY. Luminance is brightness - not color, not shade, not tone. Brighter is whiter with B&W film.
For example...imagine a flower bed. Green leaves and red flowers, in this simple case. With straight B&W film and no filters, both the shade of green and the shade of red present may have the same relative brightness - the same luminance - so they will be recorded as the same shade of gray. This may not be what we want.
So, how do we change it? Well, if we put a red filter on our lens, then we are passing more red light and blocking green. Red things move up the chain of relative brightness - and are recorded as 'whiter' than green things, which move down and are recorded as 'darker' than they otherwise might be. If the red flowers are now reflecting the most light in the scene, they record as 'white' on our B&W film. All we are doing is changing the RELATIVE POSITION of the red versus the green by applying a filter so MORE red than any other color gets through.
The same thing happens in reverse if we put a green filter on our lens. The leaves, being green, are now brighter and therefore a lighter shade of gray than the red flowers, which become darker.
With that said, it is easy to understand what the most common color filters are good for - manipulating relationships among colors.
Colored filters lighten their like - and darken their opposite (called their compliment). So red filters make blue skies dark and ominous, yellow filters less so. Green filters block red - and so can have a positive effect on caucasion skin tones in out-of-doors portraits where red or pink blotches and uneven reddish skin tones are common. However, it will darken red lipstick to almost black, and so will have a heavy effect on a portrait of a woman wearing it.
Here is a good resource:
http://www.schneideroptics.com/filters/filters_for_still_photography/black_&_white/
I think that should do it. However, by way of passing, I'd also like to address a couple of common questions about the use (or need for) color filters:
1) Can you use color filters on digital cameras? Maybe. Some work, some get confused. Some that can be put in 'B&W mode' are probably more likely to work than those that cannot.
2) Can you just use Photoshop later on to duplicate the effect of a color filter? Yes, if you shot in color originally. If you shot in B&W, or if the image has already become desaturated to B&W, then the individual color information does not exist - you cannot duplicate the effect of say, a red filter, when everything is shades of gray. What's red? What's green? The image no longer contains that information.
3) Do you 'need' to use color filters? No, not in most situations. It is merely another creative option. It is interesting because it allows us to make more distance between colors that would otherwise render as similar shades of gray, which can serve to highlight or isolate a subject in a photo and make an otherwise boring B&W photo 'pop'. Continued overuse of the same filter effects can become tiresome, however. A heavy dark foreboding sky rendered with a dark red filter is cool - but after a couple hundred of them, one begins to feel the need for a visit to the beach.
I hope this is helpful.
Best Regards,
Bill Mattocks
I have noticed tha ta lot of conventional wisdom on using filters for panchromatic B&W photos don't seem to hold up as well as they used to. By used to, I'm speaking about conventions that were commonly understood inthe 1950's and 1960's.
For example, I've noticed that I need yellow filters a lot less now than I did in bygone years to bring out clouds. Has the atmosphere changed? or has the color sensitivity of B&W fims changed over the past 40 years?
Anyone have some old negatives that they can look back to to see if this is true? Perhaps it's just a figment of my imagination.
-Paul
Bill,
When I first started reading about filters, many years ago, they were frequently referred to in the complimentary sense, such a Orange (Minus-Blue). For those with little knowledge of the color spectrum, this seemed to help understand the effect, i. e., use of the orange filter would move the blue area closer to the black. For some reason, this has stuck with me.
Jim N.
-Paul
Paul, my first foray into film was in the late 70's, so I can't really speak to the films of the 50's and 60's, but I believe that films are more panchromatic than they were. It took me a long to time to figure out that film does not respond uniformly to increases in light - it is not a straight line OR a logrithm, but rather has a distinct 'shoulder' and 'toe'. Based on this - if the shoulder and toe changed, I could understand how the need for filtration would change as well. But I am not an expert here.
Best Regards,
Bill Mattocks
OldNick said:
Bill,
Jim N.
For someone who is color-blind, such as myself, the thought of color filters for B&W work seemed counter-intuitive for a long time. However, there are not that many colors to remember, and I found that eventually I knew which filter to reach for to get a particular effect, based on past results if not on understanding. I find that I use a medium yellow more than any other filter, but a deep red is my second most-used filter. I seldom use orange or any of the combinations such as yellow-orange or orange-green or what have you. And I personally have never found a good reason to use a blue filter - and seldom a green either.
Best Regards,
Bill Mattocks
A green can be good for portraits. With many films it gives a more natural skin tone.
I have also found a significant difference in the way some of the chromogenic films handle filters compared to traditional B&W emulsions.
XP2 is generally pretty good (didn't handle a dark red filter well though) ... but I had a few rolls of Kodak's offering go muddy when a filter was used.
Good piece on filters Bill .... thanks.
Peter
There was a wonderful Calvin and Hobbs Sunday comic strip about when the world was originally in B&W and when it suddenly turned to color. I feel like that sometimes.
I have many photos taken in the 1960's where I could not seem to get those puffy white clouds to come out on film. When I finally was able to afford some filters, it took a red filter to bring them out to the level I wanted. Now, using Neopan, Tri-X or any other modern film, they pop right out to the level that previously required a medium yellow.
Something somewhere changed. Perhaps the colors of the world just changed.
Anyway, conventional wisdom from my old Ansco and Kodak brochures from the 60's suggest that a green filter will lighten green foliage to make it look more white on film. That will make it contrast more with the sky which should darken as the foliage lightens. At least if the worlds is still the same color.
-Paul
-Paul
And after it rains
There’s a rainbow
And all of the colors are black
It’s not that the colors aren’t there
It’s just imagination they lack
Everything’s the same
Back in my little town
Nothing but the dead and dying
- My Little Town, Simon & Garfunkel
Best Regards,
Bill Mattocks
As the result of much reading on the subject (a lot of it here), I felt I had a pretty good grasp of the filter / b&w film relationship - but reading your post has really simplified, or "tidied up" the whole concept for me. Thanks Bill!
I just wanted to second Scott's comment above. Thanks very much Bill for putting this subject into terms so easily understood.
-Randy
Seriously, I do think that sometimes RFF members write truly seminal pieces that should be preserved in an accessible place. Bill has written at least 2 such pieces that i can remember in the recent past.
Bill Mattocks
True and yet ...
The hardest thing I had to learn was that b/w photographs generally should have both black and white. That isn't always easy, and is why some take to the zone system so wholeheartedly. Too much gray and they are just muddy. Of course, high key photos may not have much if any black, but generally, the most successful b/w photos should have some of both, or something that easily passes for such.
Anyway, I don't mean to take away from a good post on b/w filters. Thanks for the good post Bill. I haven't done that much b/w in years. When I did more, I tended to use them more. But that was years ago. I needed that reminder to jog some old brain cells, and to make me think about doing more b/w and using filters for just the things you mentioned. Thanks again.
All of this appears to pass completely over the fact that we are not shooting b&w positive film. We are shooting negative film. I would think any attempt at explanation of filtration should include this fact. To jump from real world color to final b&w print without the actual intermediate step of the negative which is what we actually produce gives a partial and possibly confusing description to the newcomer to the field.
Unless I'm missing something (this is not an impossibility) Bill has described the affects of the colour filters in terms of the final results in print, so your positive/negative concern has been fully addressed.
