Naumoski
Really nice portraits and mood, by the way 🙂
No - this looks pretty good to me in terms of color.Am I barking up the wrong tree?
Yes, the face is too light. These two similar pics are quite different exposures. One looks good on the negative, and the other under exposed on the negative. The over exposure has been cause somewhere through the PP process. ColorPerfect will clip at both ends so I dialled in some correction in CP to bring highlights back. This is one of those scenarios where I should probably do things from scratch working with levels rather than CP.No - this looks pretty good to me in terms of color.
I still think the picture is a little overexposed - the skin tones in the girl's face are a tad too light. That, however isn't necessarily a scanning problem because there's still some detail available in the face. You can fix the overexposure using a gradation curve, or simply by pulling the brightness slider a little to the darker side (but be gentle - don't give her a suntan 😉 ).
Ok cool. I've never worked with NX. I found when playing around with ColorPerfect and doing the white bal click, a bit of work still needed to be done. I used curves in photoshop to do that. Curves has a gray dropper which helps you tweak the over color balance pretty easily.
Pete, sometimes I need to tweak the curves suggested by using the gray dropper. It takes a bit to recognize what color you don't like and what moves you should make, but moving the green midpoint left or right, or maybe the red, etc., can make a big improvement off of the curves generated by the droppers. Don't know if you have that kind of control with NX though - you do in Photoshop.
Tim Gray said:If I had a drum scanner or a flextight, I'm sure I'd be much happier with the software provided with the scanner.
For a few months I've been trying to better my scanning. I'm not sure what I want to ask. Perhaps I just need some comments on these results and some ideas how to improve my method. I scan using a V700 producing a negative Raw file with all the info. I usually use ColorPerfect then try to colour balance by eye in Nikon's Capture NX. If ColorPerfect doesn't seem to be working out I'll work from scratch in NX. Sometimes I feel my results look a little cross-processed so another's eyes would be appreciated.
These files are Fuji 800Z. Any constructive comments will be welcome. I know I'm not a great photographer but I would like to stay with film for as long as possible.
Pete
I found in Elements Adjust Colour, Adjust hue/saturation and there is any eye dropper tool in there so clicking on a patch of grey on the hat I reduced the cyan to give this result. Am I barking up the wrong tree?
Pete:bang:
I can't understand why there aren't better or more intuitive programs.
The only major thing I see as a problem is that some of the photos have a bit of a green tint to them.
I am not familiar with Capture NX, as I use Lightroom. But I would think there are similar white balance tools?
Here are a couple of screen shots with before/after illustrating what I did in Lightroom, perhaps you can translate it to NX. FWIW, I did not use the eyedropper tool to automatically balance. Rather, I just adjusted the green/magenta slider until it looked right to me. I find that the eyedropper tool it very hit-or-miss, better to do it manually.
. So it comes down to your ability to make accurate judgement and adjustment. So ultimately bad colour is down to operator error or palin bad taste 😀
