I am near reach of the M6 ... am I ?
I went with the 0.85 non-TTL to avoid battery drain and flash problems when batteries run out. Plus, the speciman I got is mint.
Raid
Ka-ching! And a rare one too. FYI, with the "classic" M6, all you need to do is set the shutter dial to "B", and you won't risk the "battery drain" misunderstood issue. I've had the same battery in mine for over a year and a half now.
Gabriel: I was told that the 0.85 is relatively rare with the M6 Classic. Yes, you are right about simply setting the shutter dial to B to stop battery drainage. I do this now.
Raid
