I can't believe how many photos I've missed with my R9.
Vickko
8:08 PM
Canada
I can't believe how many shots I've missed with my R9.
I just got back a roll, and using the 35-70 f4 zoom, missed easy shots of my 2 year old son looking right into the lens and standing still. The shots look out of focus.
I think I used f4, so there should have been enough depth of field to deal with his face, and it was a sunny day so I think the shutter speed was fast enough.
I wonder if the focusing screen is just not right for me, and my half century old eyes.
The shots at infinity look okay.
Any other R9 users with similar problems?
Vick
Hi, being re flex camera shouldn´t have such a missfocus....the best is to get a test, simply focusing on a scale metre...set wide open and 3 feet away that should tell you mny things.
Luck!
Which screen do you have? My R8 came with a plain screen. That's OK in a Hasselblad, but not in a 35mm SLR IMO, so I got a split/micro prism screen for it.
But what 'Monochrom' says makes sense to try.
Do you use the camera a lot? Trying to capture kids moving a serious business.
The aperture f4 may not be enough depth of field..I have used flash in the past, to capture movement and obtain a better aperture.
Practice focusing your camera on a few objects in a normal lit room.Use a pencil to mark your focus point on the lens. A few times focusing, will have pencil marks all over the barrel! A rangefinder usually always same. A SLR needs more practice.
It is possible your mirror and or screen not correct, but doubt it, in a camera that is not old and possibly of very high quality.
I shoot my son -- three and a half -- with digital and film both and my success rate is about 1/4 digital, 1/6 film.... Their heads, faces, eyes, hands, torsos -- are never still.
That said it sounds like your complaint might go deeper and it might be worthwhile to have the camera checked by Leica. It's by all accounts a phenomenal camera.
Just take a few test shots of still subjects - is they are sharp you may need to change your technique or get an AF camera and if they are no sharp - have the camera/lens checked. I recall that 35-70/4 should be a great performer.
Definitely odd, are you sure it is a focus issue?...how long have you had the R9? Did it work fine before? How long has it been? Changed batteries lately? The only thing I am wondering is maybe your subject was too close? Maybe the subject was moving with too slow a shutter speed? What setting did you have the camera on, aperture priority? Make sure that switch is working fine and hasn't slipped.
Try another roll with new batteries and get back with us! I would love that R9 myself! On my bucket list.
To follow up.
I just sorted about 8 rolls of holiday shots, using the same R9 and a 50/1.4 lens. Most of them were sharp and good, so, I think the R9 body is okay.
I'm in the middle of another roll with the 35-70 f4, where I'm paying more attention to technique. I'm hoping the results reveal what my problem is (e.g. focusing technique, lens problem, other?).
Oh, the focusing screen is the standard split with microprism collar. I can black it out at f4 occasionally, but it mostly works fine for focusing. Oh I think so anyway.
Thanks all
Vick
To follow up.
Thanks all
Vick
Vick, thanks for the update.... looking forward to seeing how this works out. That is a great rig you have with that lens!🙂
...I wonder if the focusing screen is just not right for me, and my half century old eyes....
If your eyes are the issue, changing the screen is not likely the proper fix. You probably need correct for their inablility to focus properly at the screen's projected distance. Most SLR screens are set to appear to be ~3-6ft away. Adjustable diopter eyepieces and attachment diopters can change that to something at which your eye's can focus. (For my myoptic eyes that is about 12-14" when I'm not wearing my glasses). This match between your eye and the VF is more critical in lower light since your eye dialates (opens to a wider aperture) reducing DOF.
If your vision difficulty is one of "resolution", rather than the common focus issues, you'll find a split RF patch the best solution. If that doesn't help then its AF time...
Great it worked out for you! Enjoy the R stuff!
I love it!
Regards,
Boris
Glad to hear it's not the eyesight! My experience over the last 2 years with failing central vision has found the Leicaflex SL to be the camera for manual focus. I had an R8 and although better than most the finder is not as nice. High magnification and a full microprism screen allow focus using peripheral vision.
When it's time for autofocus I second the F100 which these days are so cheap. The only reason I sold mine was the F5 which can be had for reasonable money now and has the fastest focus of any Nikon I've used. D4 I haven't tried yet.
Great for kids with the tracking etc.
