raid
Dad Photographer
Too many 50s? No, I only have one: The collapsible 50/3.5 Elmar in LTM.
Well, and of course the Ultron 50/2 on my Vitomatic IIa
and then the Color Skopar 50/2,8 on the Vito BL and the Color Skopar 50/2,8 on the other Vitomatic IIa
And then those, that do not count: Nikkor AI 50/1.4, 50/2, 55/2.8 and the EL-Nikkor 50/2.8 on my enlarger.
And than the one, that does not count at all: Bronica Zenzanon MC 50/2.8
So, I clearly need some more 50s. Any suggestions?
Let's start with a mini-primer:
Summar-Summarit-Summitar : One of these three classic Leica lenses would be a good start. The Summarit may give you sometimes unpredictable results when used at large apertures.
Nikon 5cm/2 or 5cm/1.4: Both lenses are superb RF lenses for your LTM camera. The Sonnar look will be obvious.
Canon 50/1.2-50/1.4-50.18: Each of these three lenses is superb. The 50/1.8 is a bargain for what it can produce. The 50/1.2 can be awesome if correctly adjusted.
Canon 50/1.5: The "perfect" Sonnar lens.
Summicron 50mm/2 : Any of the versions would be awesome.
Jupiter 3 50mm/1.5: A great lens once it is optimized for the camera.
I-50 50mm/3.5: A very sharp and cheap lens. Compare to Elmar 5cm/3.5.
Menopta 53m/1.8 (or sold as Helios 103):One of most capable FSU lenses.
Then there are the more exotic and expensive 50mm lenses that I donot own. There are also 50mm lenses by CV that I prefer not to own. :angel:
The 50mm family is large for LTM cameras. Take your pick.
