gb hill
On David's link scroll down to NKVD & you will read this:What makes you think they did do this? I never read / heard about original FED's having a copied Leica nameplate
[FONT=Arial, Helvetica, sans-serif]While under the administration of the NKVD, the Dzerzhinsky Commune did something which is perhaps unique in the annals of camera history; it copied the Leica in name as well as form. The FED was already a physical copy of the Leica, but some of the cameras were also engraved with the familiar 'Leica' trademark, and some f3·5 lenses were engraved 'Leitz Elmar'. Whatever the motivation, this strange practice persisted over several years, during which an apparently sizeable number of cameras was made. Beyond any shortcomings in workmanship, the give-away features of these cameras was the distinctive FED viewfinder window. The earliest known 'counterfeit Leica' was manufactured in 1936, while the most common year seems to be 1938.[/FONT]
Penny Lane
Hopelessly Citrophile
Those came out great, Derk.
PF
Thanks! It's just that I know which problems the negs show; it usually takes a few days for me to get over what went 'wrong'. I'm probably just strange like that
Derk
Ron (Netherlands)
Thanks for the info, that makes it clear. Indeed a very strange practice. Btw IMHO especially the NKVD FED was upto technical standards with the old Leica II.
David Hughes
David Hughes
Interesting read David. I like the design of the early Fed 1. Looks more like a true Barnack Leica than the later clones. I can't fathom what went through their minds to even clone the same Leica inscription on the camera's. Seems to me it would have been much better to show off Russian pride in mfg. instead of copying the Germans even down to the inscription, especially sinse Stallin wanted to further the Russian industrial revolution. Thanks for the bit of history. I knew some of it but was unaware it went back to so early of a time.
I'd forgotten that was in it but by the time I'd found it I had run out of time to read it in.
I think you'll find it's refuted elsewhere, as I remember it was pointed out that the fakes that turned up all differed and it was put down to private enterprise. That's what I believe anyway.
I expect someone with more time on their hands will supply the answer.
Regards, David
gb hill
I can believe that too David. No doubt you & others have done their research on these cameras. Thanks for your input.Hi,
Regards, David
Dez
Bodger Extraordinaire
I suspect it is just simple counterfeiting by private crooks, but I guess it is possible that the factory may have generated some in the 50's in a bid to source foreign currency. One thing has always bothered me about the Russian fake Leicas- the original engraving was quite deep, and to grind it down and re-engrave the top plate as a Leica would leave the metal very thin, but it is not my experience that this is the case. Looking at a couple of fakes, I have not seen too-thin metal, nor any sign of brazing over the original engraving. It appears as though the counterfeiters had a supply of unengraved top plates.
Dez
Dez
David Hughes
David Hughes
I've often wondered if they were stolen or diverted from the factory for engraving. Top plates, I mean not cameras. Once they stopped production there would probably be a few about. Ceasing production with everything running out at once is difficult...
Regards, David
Regards, David
farlymac
PF McFarland
The originator of ICCD does not use the word "Commie" in a denigrating way, David. It's done in a light-hearted fashion, to separate the older FSU stuff from the Lomo items that came later.
ICCD is a celebration of all that was good (and bad) about the Soviet camera industry. Though this year has been a bit bittersweet in that respect.
Now lets get this thread back on track, everyone. Show us your photos taken with your Commie Camera May 1 through 7, 2014!
PF
PF
gb hill
PF
Amen Phil. I dropped off my roll from the Fed 5 today. I should find plenty of time to scan them in over the Memorial Day weekend.
gb hill
farlymac
PF McFarland
I think Ferrania had an odd color when it was new, Greg. Nice work with it though.
PF
PF
mburns
The nonlinear color profiles for color negative films are difficult to improvise, even after you have good black and white points for each color with a standardized scan exposure. So the dark grays are still greenish and would require a lowering of the green curve there in the dark grays.
