fgianni
Trainee Amateur
Thanks John, see you on Sunday...Hektor said:I,ve got some.......you can have a piece.
If you are still there at 10:30 ish
I should probably do the same to my jupiter 12, but I doubt I will be able to see the difference on a 35mm at f2.8
Hektor
Leicapile
ok 10:30,
Stick the FSU lenses on FSU bodies and get leica, or vc, or zeiss, you know it's right ;-)
fgianni
Trainee Amateur
Problem is that now the rangefinder does not work anymore properly at infinity, when it says it is focused at infinity, it is actually focusing at 15ft, and when the focus is at infinity the rangefinder says I am focusing beyond.
Aaargh what do I have to do!
Hektor
Leicapile
If you want to pad the cam with tape to get it right at close-up, then you have to reset the infinity focus on the lens as well. either by repositioning the scale or by resetting the helix, depending whether true infinity focus is acheived.
Definately see my previous post. Get a fed. ;-)
fgianni
Trainee Amateur
Brian Sweeney said:The Nikkor 8.5cm F2 will, of course, work perfectlt.
And is of course outside my depth of affordability...
fgianni
Trainee Amateur
Hektor said:Definately see my previous post. Get a fed. ;-)
Do they make digital ones?
Hektor
Leicapile
Yeah, but like the early digital watches, you need a wheel-barrow for the battery....;-)
i don't know how to insert smiley symbols !
fgianni
Trainee Amateur
Essentially now I can focus spot on at 1.15m but when focusing at 12m (and the image at 12m is spot on) the rangefinder indicates focus at infinity, while if I focus at infinity (and get the image at infinity in focus) the rangefinder indicated focus past infinity.
I think I can somehow compensate for this, much easier than being 3 inches off at 1.15m, however it would be nice to have the lens calibrated correctly somehow.
fgianni
Trainee Amateur
So essentially it looks like Russian LTM lenses are not compatible with western ltm cameras.
Use Jupiters with Zorkis and leicas with leicas.
