lxmike
M2 fan.
Get a Summar or a collapsable Elmar, vintage glass, low contrast, flare etc but hey thats good as it give your images plenty of character. Good luck in your quest for a lens.
This CZJ 5 cm f/2.0 from the 30's is kind of the B57 of the lens world. It works, it works very well and while a lot of bombers have been made since the B57 still is flying as a reliable, front-line device. The B57 is a rugged workhorse. .
There are three WB-57F Canberra aircraft still in service with NASA, amazingly. I worked on an airborne experiment that went up on one some 35 years ago. Traces development back to the British Canberra of the 1940s. Flies high, straight, and slow.
The Sonnar is more of an F104. Built for nothing but speed.
I worked on a special component of the B-52H during the 2010’s. Yes, they are scheduled to be in service till 2045. About 90 years. Quite extraordinary.
Marco Cavina posted this on his site, and shows the original design of the 5cm F2 Sonnar having the middle triplet as a curved surface. His site has more information on the Sonnar than any other that I know of.
http://www.marcocavina.com/articoli_...age/00_pag.htm
Many different formulations of the 5cm F2 Sonnar are shown. So- the question is When were they in production, which was selected for the J-8.
This may have been changed. The middle triplet of the CZJ Sonnar 5cm F2 is stamped into metal.
I know for a fact that the 1970 J8M uses a curved surface - because I split them.
This graphic also shows how the Nikkor is almost an exact copy of the Sonnar in terms of glasses used, while the Jupiter-8 is a different lens. And then they say the soviets were copycats...
The Nikkor is 51.6mm, rather than 52.4mm.
I just picked up an early 1952 J-8 in Contax mount, should be here this week. I'll give it a CLA and make sure it is shimmed appropriately. Will compare with my other two 1952 J-8's. Early J-8's are made with Zeiss cut glass, sometime in 1952 switches over to Russian cut German glass. After the supply of German glass was used up, Russian glass was used. Production of both Russian glass and German glass Jupiters occurred in parallel for about 1 to 2 years, based on taking apart KMZ j-3's.
I've been going through Sonnar diagrams from 1932 and J-8M diagrams on the web. The Sonnar 5cm F2 of 1932 did have a flat surface between elements 2 and 3. The diameter of the elements were all the same, making it fairly easy to align. At some point the design was revised to a curved surface, at least according to Neblette in Photographic Lenses. The J-8 is also shown with a flat surface, elements all the same diameter. The original design of the J-8M has the flat surface, but the third element of the triplet has a smaller diameter than the first two. You need a really precise jig to hold it precisely in place on a flat surface exactly centered. ANYWAY! That's my observation. By 1970 or so, the J-8M was revised to use a curved surface. I heated one up and dropped into cold water to split them apart. I do not suggest repeating this experiment,.
