leica m4 frame spacing
Michael I.
11:34 PM
Israel \ Ireland
Hi,All!
I recently purchased a M4.I found it to have frame space issues:
1)the first couple of frames are ok
2)the next several overlap
3)then - 2/3 of the film is blank
maybe I am loading it wrong?
What could be the problem?
Thank you!
Mike
If the frames are overlapping your camera has a bad clutch and needs a CLA.
As to your blank frames, it could be bad exposures - this suggests the shutter also may be out of tolerance and in need of a CLA - or you're shooting with the lens cap on.
If the first few frames are okay, then the film is most likely loaded properly.
a bad clutch seems to be the case.
I will search for a CLA expert(I have a very positive experience with Youxin Ye)
