None of the framelines in the .85x M6 will be usable with the 25mm lens (the 35mm framelines are right at the edge of the viewfinder). You will need an accessory finder to compose with that lens.
I'm currently using a 28 on my M6 .85 and it seems the images are a bit wider than the edges of the viewfinder, something I don't particularly mind. But obviously - my opinion only - you ought to get an external viewfinder for a lens as wide or wider than 25.
