raid
Dad Photographer
Yes, you are right, Erik. The rewind knob can be pulled up. Such old cameras are a lot of fun to investigate.
Thank you, David. If you one day have the time to look for the information on Standard camera with twin accessory clips, please do.
The model Ic came with two accessory clips, also called an OEGIO. It was made from 1949 to 1952 but had the blank cover instead of the slow speed dial. So we are none the wiser. (Two were also a feature on the If and Ig.)
OTOH, the Ur Leica also had two clips and that suggests it was something the factory and dealers knew about it and could offer it when needed. Or you could be amazingly lucky.
I don't know your opinion, or anybody else's, but I have often thought that there were dozens if not hundreds of non-standard Leicas made and non-standard bits and pieces for them. Over the years you see all sorts of weird things turn up...
I'm sorry I can't help more.
Regards, David
I think I can see two little bumps in front of the second shoe —— I guess these are the remnants of the original finder's fastening?
I see them too. So maybe someone removed the 5cm VF and placed there a second accessory shoe. Why? When? By whom?
I guess this was done to use the camera with a wide angle lens, 35mm or 28mm. One of the clips was used for the viewfinder and the other for the rangefinder. The rangefinder was mounted vertically. With the 50mm finder still in place and the rangefinder in the accessoryshoe the camera could only be used with a 50mm lens.
Also a VIDOM (universal finder) could be used in one clip and the rangefinder in the other.
With two clips the camera is much more universal than with one clip and a fixed 50mm finder. It is WW1 technology but will work fine.
Erik.
OTOH (2), an unknown, or forgotten, Leica prototype did turn up as in Hans-Günter Kisselbach's ebook:-
https://lhsa.org/2018/04/book-review-barnacks-first-leica-by-hans-gunter-kisselbach/#myaccount
I just wish a solid, printed version was available.
Regards, David
Hi David,
In what sense did you mean that I may have been lucky here? Is my camera "maybe" a "rare model"?
You are most likely correct about having many non-standard Leica cameras around.
BTW, the shutter button on your one makes it very early but, as has been mentioned, where's the hockey stick infinity lock? I hate to say it but I feel it ought to be stripped down in the search for other clues...
