Erik van Straten
Thanks, yes it is a great piece, very good for portraits. All the engravings on this lens are Woods metal.
Erik.
Erik.
Based on what Erik has said about the engraving, your chrome Standard should not have such metal engraving. "The black pre-war Leicas have such engravings, not the chrome ones."
BTW: Wood's metal —— the original recipe —— is quite toxic, hence it's recommended to *not* lick your camera or lens clean 😉
What was special about the black cameras and lenses that made Leica use this special engraving method?
I may have an old (black) Leica Elmar 9cm 4.0. It may then have some fancy engravings!
This type of engraving is called Woods metal (there are also other names for it), it is a very expensive type of engraving in the metal that is filled with a hot, liquid metal, a mixture of lead and silver. This liquid metal solidifies as it cools and then forms the engraved numbers, letters and signs in a positive (convex) relief. This process has not been used for a long time and it is now impossible to imitate. The black pre-war Leicas have such engravings, not the chrome ones. This type of engraving can no longer be copied nowadays. So when your prewar black Leica has such engravings it can't be a fake.
Erik.
Erik,
I always thought Woods metal was a very low melting point solder - an Alloy of Bi/Pb/Sn/Cd
This would make it easier to melt and fill in the engraving at <100 degC also being a eutectic it will go from liquid to solid at a specific temp and have no pasty region. Not sure what flux would be used
If Pb/Ag depending on the alloy % the melting pt would be significantly higher.
If you are very brave...
I understand that if you heat the 'woods metal' from behind you can get it to melt while staying in the engraving. When it dries it will be as it was when new.
I can imagine this working, the melting point is low and presumably lower than that of the paint around it.
If I could find a 'cheap' Leitz accessory to have a go on I would try but have yet to come up with anything. Ideas?
Just don't try it and then blame me for the resulting disaster!
I think this pic of my III with my 1951 IIIf shows the 3D effect of the Wood's metal engraving that Erik was talking about on the earlier Leica, and the more silver less creamy look of the chrome plating compared to the nickel.
John Mc
